Fuel Return To Tank (not basket) Question
- Replies 18
- Views 2.6k
JAG1 5 posts
Stanley 4 posts
Mopar1973Man 3 posts
Tractorman 3 posts
I connected mine to the filler neck vent 'T'. I simply stepped up the rubber return line hose bigger to adapt the the fill vent nipple. I was worried at first how well or how fast I would
Since I figure I will have my truck forever, I just modified the bed to allow access. The top of the photo represents the front of the truck. Many holes are drilled and tapped for easy removal.
Nice! On mine I ran steel tubing front to back underneath to help support the cut bed frame and for the access Door I used 1/4 inch diamond plate since the bed is corrugated to 1/4'' thick. It's like
What is a good, economical means to return the fuel to the general tank versus returning directly to the basket? Can a guy splice a tee into the filler neck VENT? Should I obtain the Airdog/Fass style tee that goes in the ACTUAL filler neck hose? I'd prefer something where I don't have to drop the tank.
I bought a 3-way ball valve so I can seasonally return to the basket in winter, or to the tank in the summer.
It's ~75 degrees here this morning, and by the end of my 23 mile commute the fuel was over 120 degrees running empty at 65-70 mph for most of that time. Fuel gauge at 1/2, so probably around 10 gallons in the tank. Trip meter at 400 miles. Two years ago my fuel was 160 degrees running empty on flat Iowa highways, so I know it gets hot.
