RockAuto.com cab size question - extended cab vs quad cab for headliner
- Replies 16
- Views 4.5k
Mopar1973Man 4 posts
Hutch24v 4 posts
IBMobile 2 posts
Doubletrouble 2 posts
I would say the highlighted on is the one you need if you have a quad cab. The description even states " 2 full size doors plus extra room often with half doors behind" then it cuts off.
Won't work. You need to scrape the old foam backing off the fiberboard first.
I replaced the headliner in my Jeep Cherokee a while back. Relatively easy to do. Pull the fabric, scrape off all the old foam, make sure its clean, test fit the fabric (trim where needed). Spray a
I know everyone likely has ordered something from rockauto.com at some point. There customer service is non existent and their site leaves something to be desired, but perhaps that's part of their charm! Anyway my question is on the below. Do you reckon the extended cab refers to a 2nd gen "Quad cab" per their cab size guide picture below? Want to order a new replacement ACME headliner but i'm not certain an "Extended Cab" fit is for an actual Quad cab and there's no way to ask rockauto.com. Anyone hazard a guess?
