Factory Heated Seat Replacement
- Replies 19
- Views 8.2k
I wish I had info for you. The Rostra switch sure looks "stock", not gimmicky. https://www.rostra.com/comfortheat-automotive-seat-heater-by-rostra.php Also, if your cushion isn't grea
I pulled my seat heaters out when the seat bottoms were recovered. Don't need them in southern California. I still have them in a bag somewhere.
Sounds like you can do a bit of sale for what you got for what he needs.
My drivers side seat heater has never worked, I get the flash indicating a break in the circuit somewhere. I try to keep everything factory so I started working on fixing it yesterday. I couldn’t remember why I hadn’t done it sooner. Well I’m a jackass…now I remember why I never tackled this project. Long story, I’ve ordered a new bottom seat cover. Does anyone know of an aftermarket heat pad that will work with the factory module? Any suggestions on salvaging the oem pad or should I just suck it up and install an aftermarket pad with a new aftermarket switch?
