- Replies 29
- Views 3.2k
Doubletrouble 7 posts
Andyba20 6 posts
IBMobile 4 posts
JAG1 4 posts
@IBMobile, there should be one some where out there. There are plenty of snowflakes in Cali.
Why yes, there are plenty of snowflakes, but they all melt when they hit the ground and they don't amount to anything.
We don’t see cold like this very often in Tennessee, here are my anecdotal observations so far. 1.) I’m going to switch to synthetic PS fluid. My pump and fluid are 6 months old, but had a hard time t
I have to get outside today and put the back blade on the tractor for any bigger snow. Also have to get the old wheel horse out of the pole barn for the snowblower. That works well as long as you don't overload it.
Need to get some weight in the truck bed as well. It's hard to weigh down a 1 ton dually for winter driving. I have several RR ties, I'm going to put 1 layer of them between the wheel wells to see how many fit.im thinking 4-5, they're 8 footers so they weigh in around 150lbs or so a piece. That'll be 600-750lbs, hopefully that will be enough. If not, I'll dump snow on top if them. Lol
Another thing on the list will be to bring out my heavy extension cord for the block heater. I generally don't need it but it's nice in the morning to fire up the truck and have a little heat right away. Plus it keeps the grid heaters from pounding the alternator and batteries so much.
