 So, weather sucks. It's like 4°F here with wind chills of -25. Truck won't start. I though it was gelled up. Poured power service in the tank, went to pour some in the filter housing and the fuel in there is fine. I reinstalled the filter top. Still no start.
 Put a fuel pressure test gauge on it and no fuel pressure. :ahhh: truck was plugged in, ran fine before thos cold weather, plenty of fuel pressure before also.
 Is it possible the lift pump froze?
  • Replies 36
  • Views 3.4k
  • Doubletrouble
    Doubletrouble
    All very good information to take into consideration both when changing filters and when dealing with a freeze issue.  I will keep this info stored away in my memory banks (sometimes they freeze
  • Can you imagine an upside down picture of @wil440with pins in his eyes!?   Here is something that will help build trust in the government.  Not.   In the mid '90's, my wife and I moved from
  • Doubletrouble
    Doubletrouble
    The filter housing and LP are in the stock locations. I belive the small factory line from the tank to the LP could be the issue.  I may have gotten a little air in the filter housing when I remo
Where’s the filter housing? Where’s the pump? If your filter housing is in stock location maybe there was enough heat from the block to keep it from gelling, and the fuel lines to the tank are gelled? Could you have gotten air in the line when you were checking the filter? Just theories.
 I may have gotten a little air in the filter housing when I removed the top but minimal.
 I'm gonna go back out and try to get some heat under the truck with a salamander heater to warm the lines. It still windy so I don't know how that'll work.
I don't think he got air in there unless the fuel somehow drained back to the tank when taking off the cap. I think running a heat gun to all fuel lines, lift pump etc. will do the trick. It should work if you warm up everything further away from the warmed engine. You could use a temperature laser gun to see who is the coldest under there.
Where's Mike Nelson BTW, he headed out for Seattle didn't he? has anyone heard from him?
Don't cook anything under there Boss!
 I haven't heard from Mike.
 A heat gun might be a better option. Be easier to control where the heat goes that way. If I can get her fired up and stay running to warm everything I have some fuel treatment to prevent it from happening again.
Make a wind block out of cardboard, plywood, table turned on its side, and a tarp.
He's gotten real good at makin' those with me around camp.
Michael Nelson made it home just fine, is in good shape... I talked with him on the phone since I was concerned.
I think here in the UK the winter of 87 was a really cold one for the UK with lots of snow, I was working at the granite quarry in the little village where I live IIRC it was around -15c to -20c
We had 2 Ford D series ex fire trucks, crewcabs with Perkins V8 diesels which were used as maintenance trucks around the quarry, both froze in the middle of the yard, diesel lines and air brake lines all froze, they both had oxy/acetyline cutting gear on board it took 2 of us over 2 weeks to get those trucks moving again, the diesel lines weren't too bad and every morning after starting everything else it didn't take long to get the diesel liquid again and engines running, the brake lines were the big problem we'd get thawing then it's the afternoon and getting darker then the cold just refroze everything again so next day back to square one.
I'd be getting something in the tank to lower the gell point (guess you guys have that all the time) then suck it or blow it through the lines to the LP and filter and then see if the VP will bleed
I take it the grids are working ok ?
@wil440, yes the grids are working fine. I was messing with it yesterday and got it to shiw fuel pressure so I would bump the starter and just let the pump run for 20 seconds to try and bleed it through hoping to pull the now treated fuel through the lift pump. It was showing pressure at the test port on the vp44. Then I tried to start it. She fired and ran for about 30 seconds and died again, list fuel pressure.
 I'm hoping this didnt simehow take out the lift pump. Its a raptor 150 and has less than 10k miles on it.
I'll mess with it more today, the outside temp is a bit better. It's 12°F now. Yesterday it was still in the low single digits.
 Also had the battery charger on it all night at 6amps, maybe that'll help. I don't know. In all my years of truck driving this is the first time I've had anything freeze up in the fuel line like this.
I am hoping warmer temps are heading your way since we went from 22* to 45* in 24 hrs. Also seeing weather coming from the south eastern Pacific which is always a warm temperate pattern. I have in the past used a shop vac with the hose placed into the outlet blowing side of the vac with a rag blowing into the fill neck to prime a couple times but you have to have a portion of the fuel line open to see when fuel starts flowing. A problem with that is your expanding the fuel tank at the same time so I always did short blasts of air so I didn't damage anything. I would open the line to the VP and have someone watch for flow and tighten it yourself because those threads are aluminum and you do not want to wrench them and strip them light snug is good and if it weeps then a bit more till it stops. You might get it this way anyhow. Sometimes I think its good to just let quite a bit of fuel thru and guarantee there's nor air but, it makes a mess sometimes.
We need her running so you can go camping with us LOL!
 I would love to! Wish ya'll weren't so far away, it would be a great time I think.
 Today I'm going to open a fuel line in a spot or two to see if I have flow. What concerns me is I'm not showing any fuel pressure at the test port on the vp.
 Also going to check for power to the pump to be sure she's getting juice.
 May have to line up a couple tables for a wind break and ppint the salamander under there also.
 We have family coming over today so my truck time will be limited.
 Just drives me crazy knowing she's out there but won't start. Don't know why but it irritates my soil. Lol
@Doubletrouble, in the early stages of diesel fuel gelling, wax crystals form.  The wax crystals typically collect and block a filter or a suction screen.  The rest of the fuel in lines and the fuel in the tank are usually okay.  The fuel in your fuel filter may look good, but the wax crystals may have formed which will make it difficult for fuel to passed through the filter.
If you have a stock fuel basket in the tank, then the fuel inlet screen is likely to be restricted in the same manner.  Not much you can do about that one, except maybe build a protected area under the fuel tank and apply heat with an electric space heater - carefully!
You could put a drop light with an incandescent bulb under fuel filter housing in the engine bay and block the air flow around the filter housing.  I would not crack any fuel lines open anymore, as there is no benefit and you do risk introducing air each time.
The likely reason the engine lost fuel pressure and died is because the VP44 internal vane pump (you know, the one nobody talks about) is pumping fine and was trying to draw fuel in faster than the lift pump and related components could provide.
I don't think your lift pump is damaged.
Be patient - think it through..., enjoy your Christmas Day!
- John
Sorry for your troubles. If the LP is in the stock location, I would hope you are providing the DC through an isolation relay?
The original 12 volt trigger line that powered the OE LP is the line you use to trigger the isolation relay. The isolation relay only sinks about 20 or 30 milliamps directly from the MOSFET driver in the ECU.
The original LP would sink about 5 amps off this circuit because the little Carter LP is a peanut whistle pump.
The AirDog Raptor most likely sinks about 7 to perhaps 8 Amps....the isolation Relay eliminates the current demand from the MOSFET driver within the ECU because it is no longer powering the OE LP...this is a good thing.
Not an issue, your Raptor has the ability to purge the filter canister and out-flow the residual air through the over-flow valve at the rear of the cylinder head when the CTD is NOT running.
3 hours ago, Doubletrouble said:
I was messing with it yesterday and got it to show fuel pressure so I would bump the starter and just let the pump run for 20 seconds to try and bleed it through hoping to pull the now treated fuel through the lift pump. It was showing pressure at the test port on the vp44. Then I tried to start it. She fired and ran for about 30 seconds and died again, lost fuel pressure.
Good, you got it to "show fuel pressure" NOW stop this "twenty second" run stuff right NOW!
Get yourself a couple of test leads with little alligator clips about 12 inches long or perhaps longer (no worries)
Un-plug the trigger line from the ECU that "is supposed to be" triggering the isolation relay.
Take your test leads and connect them to the relay coil pigtail that was previously connected to the ECU trigger line.
Now, take your test leads and source 12 volts directly to activate the isolation relay.
This will force your Raptor into "a continuous run" condition, because you have manually provided 12 volts to trigger the relay.
You should hear the Raptor run immediately when you trigger the isolation relay. LET IT RUN !
NOW, go open your fuel filler door, remove the fuel cap and put your ear to the hole at the filler-neck and listen. Once you hear fuel being returned to the tank you should see fuel pressure. If NOT, your "peanut-whistle" feed-line has a frozen booger clogging the pathway.
Good, leave the 6 Amp charger hooked up while you do this and let the Raptor RUN !
NOTE: quiet conditions are required when you are trying to hear liquid flow being returned to the tank.
I know it's cold and miserable at your location...stay with me...
In this "force run condition" this effort may require getting under the vehicle with an industrial heat gun and began "heat tracing" your peanut-whistle fuel lines.
BOTH feed and return must be HEATED to restore the full circulatory aspect of your system.
It will cause NO harm to continuously force run your Raptor in this TEST scenario and the battery charger will prevent pulling the head-charge off your storage cells.
The force run condition without the CTD rumbling in your ears should allow you to "listen" for success once the system is fully purged and free-flowing.
Most likely, you'll see a fuel pressure indication once flow is achieved.
I strongly believe following these suggestions carefully and remaining focused on the details will yield successful results.
Removing your temporary test leads and restoring your ECU trigger line to the isolation relay, returns your system to standard operational condition.
Please, do NOT "test lead" 12 volts into the ECU trigger line...that, is a direct act of buffoonery!
Merry Christmas
W-T
 Thanks to all that have helped! I finally got her fired up and running.
 W-T, that was a great testing scenario! Unfortunately I did not read this until after I was finished. BTW- I do have the lift pump on a relay to avoid pulling the amps required through the ecm.
 To sum it up,  I got her to build pressure so fired her up. The fuel pressure would slowly tapped off to near 0, I shut it down. Reprimed with a key cycle and restarted. Did this about 4 times and she started holding enough pressure to safely idle, around 10psi.
 As it idled things began to warm up and the fuel pressure was rising as well. Once fully warmed the fuel pressure was back to 18psi at idle. If I would rap on it she did not drop below 15psi. I let her idle in the driveway for a good 45 minutes to an hour before a test drive around the block (about 4 miles) then let her idle some more while putting tools away.
 I believe there may have been some gel or icing somewhere in the lines or pump.
 At this point there should be plenty of treatment in the tank to avoid a repeat. I poured 64 Oz. Of power service 911 red bottle in there to begin the thawing process. Then 32oz of the white bottle power service to prevent gelling.
 Should be plenty!
 So this is my Christmas miracle I suppose. Thank you all again for your ideas and advise. I greatly appreciate it!
John, of course...I'm just doodling in the office. It's early Christmas morning and still sober...not for long :rolleyes:
Both these members have good intentions so let them be as covert as they like :thumb1:. W-T has good camouflage for his truck.... I can barely make out what it looks like with his Girlfriend standing in the front.
7 hours ago, Doubletrouble said:
 Just pickin @JAG1.  Glad to see W-T still pops in from time to time and insightful as always.
I know you where and its cool.
Yeah...John @Tractorman brought a few aspects to my attention that need clarification to this issue for @Doubletrouble
The run-time for the lift pump in a freeze-up situation is dependent on how hard frozen is it? Also, where is the frozen obstruction or resistance?
My error in stating "Let the Raptor Run" is not fully correct and needs to be tempered in application.
BTW...prior to applying a new lift pump installation on my vehicle, I would use this "TEST lead, force run" procedure when I would change the fuel filter in the Stock Filter canister.
This simple maintenance procedure always evacuates the fuel within the canister as you remove the filter element. Once done, I'd reapply the cap and tighten to prevent leaks.
Knowing, I had air in the system, I elected to "force run" my lift pump to purge the system prior to starting the engine.
This procedure actually trained my "ear" as to what was occurring within the circulatory system by the way it sounded as it hydraulically chased the air from the system. It is a subtle but, very profound audio report and you need to experience this to gain the auditory perception of its action. It is also an advantage to have a working fuel pressure gauge to visually monitor "what you hear" as the hydraulic system stabilizes. Viewing the gauge as you "force run" the lift pump you'll see some wild excursions as the system purges the large volume of air and begins to become a "pure air free" liquid environment. It requires "run time" to actually hear the system clean up...as the lift pump continues to run, you will hear the finalization of complete purge and your system will have a certain sound that is very particular.... it sings it's own song.
On initial activation of the lift pump in this "forced run TEST" the sound is raucous and glancing at your fuel pressure gauge instantaneously will be alarming as the needle will slam itself violently as the purge initially is vacated then, you will begin to hear stabilization but, additional run time is still required as the fuel pushes the last remaining air pockets from the system. The entire lift pump circulatory system will adopt it's own sound and remain at that same sound once fully burped.
This "TEST force run" of the lift pump with the engine NOT running is an enlightening experience and one should know the "song" of your system. Each system has a different song and depends on what devices are selected in the assembly. I know that Dan @IBMobile made reference to force running a lift pump in a thread sometime back, so this TEST procedure is not new.
Flow through is important, even if its just a dribble of fuel indicating liquid fuel is present within the vane cavity of the transfer pump. My blanket statement to @Doubletroubleto "Let the Raptor Run" in this "TEST force run" is in error! The examples @Tractorman posted regarding "waxing" in cold conditions is a major consideration where NO flow through is occurring. In a common sense aspect, if the system is gelled-up at a particular location within the system, inadvertently placing your lift pump into a "forced TEST run condition" for an extended period of time could damage the lift pump seals following the love-joy coupling at the impeller disk.
I ask forgiveness in following verbal dissertation...if you know the "song" your system sings when all is correctly flowing, you will know when the song goes wrong.
The lift pump in a harsh low temperature situation maybe looking into a "dead headed" no flow pathway, if there is just a small fraction of liquid fuel within the cavity of the pump, it will be in cavitation and extended run periods could cause damage.
With this cautionary knowledge one would call on a reasonable consideration when placing the transfer pump into extended forced run operation. In my experience, I'd be listening for the song.
Knowing of the cold storm situation in the eastern states this winter, there is most likely, additional cold-start event errors forthcoming.
I'm originally from Butte, Montana and I've seen -60 F however; my 2nd Gen has only seen -20 F and I had no errors.
Humble Respect,
W-T
Edited by W-T
grammer
