NV450 5speed blew at 184k miles.
- Replies 45
- Views 7.5k
Doubletrouble 17 posts
Mopar1973Man 11 posts
Great work! 5 posts
Tractorman 3 posts
I finally have time to put together a price list of what i bought to do this job. Sorry it took so long...... @Royal Squire Allstate gear: counter shaft Part # NV22657
Well she is starting to look like something. I've got the mainshaft installed, 5th gear syncro installed. Got held up since I don't have any hi-temp red lactate. I'll pick some up tomorrow. I'll need
When I'm completely finished I will give a cost breakdown. I had to buy a few tools to do it so I figured that in as well.
As the title reads, yes my 5 speed NV4500 ate itself at 184k.
Some quick background, I bought the truck used with 138k on the clock.
Now after some conversations with @Mopar1973Man I should have dumped the oil in everything on truck right away after purchase and replaced with new but i did not (now regretting it). I dont believe the fluid was ever changed.
Now, I have been searching for a rebuilder near me to get this done. I was thinking of doing it myself but decided it may be best to leave it to someone that knows these things better thatn i do. Ive never rebuilt one before. Problem is, i cant find anyone around me that does it anymore.
So now my options are rebuild it myself or buy one online, have it shipped to me and install it.
There is more than just the trans that needs replaced now also. Looks like the rear main seal on the engine is leaking, clutch throw out bearing was getting noisy before the trans blew as well and during removal of the transmission the mount fell apart.
I have already received my replacement clutch, I went with a southbend clutch, single disk HD organic towing clutch good for 450hp and 900 lb/ft torque. This was a kit that comes with new flywheel w/pilot bearing installed, new bolts, disk and pressure plate and throw out bearing.
I'll need a new transmission mount, new rear main.
And now for what you've all been waiting for.......pics......
