NV450 5speed blew at 184k miles.
 As the title reads, yes my 5 speed NV4500 ate itself at 184k.
 Some quick background, I bought the truck used with 138k on the clock.
 Now after some conversations with @Mopar1973Man I should have dumped the oil in everything on truck right away after purchase and replaced with new but i did not (now regretting it). I dont believe the fluid was ever changed.
 Now, I have been searching for a rebuilder near me to get this done. I was thinking of doing it myself but decided it may be best to leave it to someone that knows these things better thatn i do. Ive never rebuilt one before. Problem is, i cant find anyone around me that does it anymore.
 So now my options are rebuild it myself or buy one online, have it shipped to me and install it.
 There is more than just the trans that needs replaced now also.  Looks like the rear main seal on the engine is leaking, clutch throw out bearing was getting noisy before the trans blew as well and during removal of the transmission the mount fell apart.
 I have already received my replacement clutch, I went with a southbend clutch, single disk HD organic towing clutch good for 450hp and 900 lb/ft torque. This was a kit that comes with new flywheel w/pilot bearing installed, new bolts, disk and pressure plate and throw out bearing.
 I'll need a new transmission mount, new rear main.
 And now for what you've all been waiting for.......pics......
20231107_125742.jpg.7d592b646300983094217aea9d01e441.jpg20231107_125733.jpg.ef731634b30826c8bc1ea0f18b18071d.jpg
  • Replies 45
  • Views 8.8k
  • Doubletrouble
    Doubletrouble
    I finally have time to put together a price list of what i bought to do this job. Sorry it took so long...... @Royal Squire    Allstate gear: counter shaft Part # NV22657
  • Doubletrouble
    Doubletrouble
    Well she is starting to look like something.  I've got the mainshaft installed, 5th gear syncro installed. Got held up since I don't have any hi-temp red lactate. I'll pick some up tomorrow. I'll need
  • Doubletrouble
    Doubletrouble
    When I'm completely finished I will give a cost breakdown. I had to buy a few tools to do it so I figured that in as well.
Looking good, on oil IF I had a manual trans it would get Cat TDTO50W  as in Tranmission,Drive,Train,Oil  50Weight   good enough for some really serious heavy mobile plant.....  THEN use Cat SOS oil sampling to let them say when it needs to be changed but then again I use SOS kits all the time as no oils now are changed except engine oil until the oil fails a lab check, saves mobile plant operators millions of squids
At least for the 50 weight I'm running I've noticed the Mobil 50 darkens way quicker than the Valvoline 50 weight I'm using right now. Seriously though I think people are holding tight to the thin lubes like the 75w-85 on the 5-speed and PennzOil Syncromesh which is TOO THIN to make the GL-4 grade. Then when you are adding horsepower you need to thicken the lubes in the axles and transmission to prevent damage to the hard facing of the gears.
To be fair the Cat TDTO  is dark anyway, I'm considering using it in my axles as it's good enough for 100 ton dump trucks and I have plenty of Cat Friction modifier to stop the chatter, my diffs are 85/90 right now with Friction modifier but TDTO50W I think would be better as it's a bit thinner but very high shear if that's the right word..
Interesting. I've not seen CAT TDTO fluids around here but I guess I should look around.
If i remember correctly the main shaft barely fits through the opening and it helps to have the input gear out and one of the front gears goes on once the main shaft is partly installed, very tricky.
Then there's a roll pin that you should get started into the reverse shift fork before placing it back in the case and tapped into place in the shift rail later with a long punch. Also very tricky.
Edited by Great work!
Clairty
Well she is starting to look like something.  I've got the mainshaft installed, 5th gear syncro installed. Got held up since I don't have any hi-temp red lactate. I'll pick some up tomorrow. I'll need that to install the 5th gear nut. Then put the side pto covers back on and add some oil. Lol kind of shift through the gears on the bench before I put it back under the truck. Trying to double check everything since this is my first manual rebuild. Fingers crossed!
9 hours ago, Royal Squire said:
Curious how much $ you will have in this rebuild?
 Got some more work done. This has been a long process but there were outside forces slowing me down.
 I finished the build on the trans, installed the 5th gear and special locking nut with plenty of red loctite as well. Installed the new cast iron tail housing then painted the case.
 Then installed the new flywheel, disk and pressure plate.
 Top is back on the trans, a light coating of grease on the input shaft and housing to ease the install through the throwout bearing, disk and pilot bearing.
 She is ready to install. I have help coming Saturday morning to assist the install. Fingers crossed she'll be back on the road tomorrow afternoon.
OMG! Come on now @Doubletrouble you put that nasty dirty lid back on? :tease:
The rest of it looks awesome... Really clean assembly inside and looks great. I'll send you my transmission for you to rebuild. :whistle:
 Well, truck is back together. Unfortunately it will have to come apart again. When put into 1st gear it immediately pops out of gear as the clutch is released.  All other gears seem to be just fine. I have to admit I was severely disappointed when I discovered this. I've put some good time and effort into this in the midst of other things in life I've had to handle lately.
 Plan is to run it as is until spring/summer and pull the trans back out and investigate.
I can only imagine how you feel.  I am sure you have thought a lot about what could be causing this - any ideas at this point?  Any possibility that it could be something external (just being hopeful)?  Does the shifter feel like it is making its full travel going into first gear?
- John
@Tractorman,
 I have been racking my brain thinking of what could have been wrong. I have found the problem! In reviewing pictures of my build and comparing them to other pictures online I noticed I have installed a synchronizer ring facing the wrong way.
 On one side it has a bevel or a slope to it, on the other it is more of an "L" shape which would enable it to recess below the teeth of the gear next to it up against the gear face.
 Below are pics that I have circled the shift ring that is backwards.
This is my install....incorrect
Now the proper way below
 If you look closely at the syncro ring you'll notice the sides are different. With the sloped side against 1st gear it won't allow the ring to travel enough to fully engage the 1st gear syncros.
 With it flipped to the proper orientation the ring will be able to recess up against the face of the gear and fully engage the 1st gear sycros.
 I hope I explained that all in a way you can see it. Sometimes my explanations can be clear as mud.
 Lesson learned here. I will run it as is until warmer weather returns. It will be an easy fix once the trans is back out.
Your explanation along with the photo is clear.  I am glad that you figured it out.  You will be in a much better frame of mind when it comes time for the repair.
- John
@Doubletrouble called me the other night about this and I was going over the 1st gear popping out in my head and I knew it was like main shaft bearings because it would do it in most gears depending on direction. I was thinking about it and the only thing I could say to @Doubletrouble something was flipped, something came loose like a snap ring but even after thinking of the direction of movement the snap ring idea would have failed. I'm glad he got it figured out and it fixable but man I know it sucks to pull the entire mess down again and just flip a shift collar.
I repaired one a few years back and almost made the same mistake. I had to really stare at that part to figure it out.
 At least you caught it before you finished and installed it. Lol
 It's frustrating but if that's the worst thing that I did I'm in good shape. Just gonna cost me more labor to make it right is all.
  • 3 weeks later...
 Allstate gear:
counter shaft Part # NV22657                   $174.25
input shaft Part # NV25356                       $62.50
master rebuild kit Part # NV4500-KITA     $379.80
                                              shipping      $55.28
                                                 total         $671.83
Transmission Parts Distributors:
cast iron tailhousing Part # 334770A        $125.77
 Thoroughbred Diesel:
South Bend Clutch Part # 13125-OK-HD   $962.40
Amazon:
NV4500 input shaft bearing retainer         $39.95
5th gear nut wrench                                  $15.50
Fel-Pro 40650 rear main seal kit                $32.90
 Other various expenses totaling                $146.00
              Grand Total                                   $1994.35
 the other various expenses were a few tools needed and the 1 Gallon of oil for the transmission.
Edited by Doubletrouble
That's a nicely detailed list.  You have to feel good completing that job.  That transmission and clutch combination will be enjoyable to drive and should take you lots of places trouble free.
- John
  • 5 weeks later...
Did you have your pick up on a lift . Did you have a good transmission jack? I helped a buddy do a clutch years ago on a square body Chevrolet. ( my only real transmission experience) What a s@#$show that was😂. Laying in the dirt underneath the truck manually bench pressing the tranny into the pilot bearing
