- Replies 26
- Views 9.2k
John 98 Cummins 8 posts
JAG1 6 posts
IBMobile 5 posts
Doubletrouble 3 posts
This should help
Key on or off there will be battery voltage at the fuse and terminal 30 of the relay. With the key turned to the start position there should be battery voltage at terminal 86 of the starter rela
I think @IBMobilehas it right. When the coil is energized, current will flow between terminal 30 and 87. - John
Hi, new member here.
I am diagnosing a no crank problem for the last few months. Turn the key and nada, no clickity click, nothin.
the first 19 times, i tapped the starter with a steel bar and it'd start then start normally for a week or so. . I dont think tapping actually had any effect now, i did think it was the starter. but starter works great. maybe a relay going bad and a few seconds to reset ?
the 20th time, i had to hotwire the starter solenoid and it fired right up, then it worked a few more times like normal.
now, after the 21st time,, i have to hotwire the solenoid each time i go to start.
I checked the voltage at the reverse/neutral switch on the starter. 3 wires on that plug.
Brn/grn stripe had 12 volts,
blk/wht had 10 volts which i dont understand that.
and purp/grn had 0 volts.
jump the Brn to Purp and the reverse lights come on.
Jump the Brn to Blk does nothing as far as starting or getting juice up to the starter.
Codes are P0122 , APPS, its been there for a long time. P1693, this one i havent seen this code before this problem. it is Trq converter solenoid.. ?
what do i troubleshoot next ? the ignition switch ?
