ECM failure
Maybe some of you gents can help me now? :)
Truck starting getting some bumpy rpms this afternoon. Drove it a bit and now it’s limping along with erratic idle. CEL on now.
Codes I have:
p0606
p0113
p0118
p0121
p0123
I read an article from here with someone with the same issues/codes and it was an ecm failure.
I have the WT mods done, batts are clean & tight.
I’m sitting on the side of the road right now so I thought id drop this topic. Any recommend ecm rebuilders?!
Thoughts?
Edited by Mace
  • Replies 28
  • Views 5.1k
  • Big thanks to you for getting those computers back to me.    Also, I messaged Mike on here this morning and he was a phone call away in no time helping me source this issue! That’s a community
  • Wanted to show something here. Here’s the new APPS, number on it is 133284, same as the Timbo. Even though I ordered a 131973 this is what comes now.   You can buy these at any truck dealers
  • Well the girl is starting to come together. My Nations 180 showed up today and I’m going to install it on Monday. I’ll make sure to clean all the mounting surfaces to ensure a decent ground.
Anything I can do to prevent it from happening again? I read the alternator can cause this?
Test for AC noise from the alternator while the truck is running with no accessory’s on. Anything below .05 mv is acceptable. Above that replacement is necessary. I’ve been running a Nations alternator for years with no issues.
Additionally, I would take the truck out and drive it a few miles to put a good charge on the batteries after starting cold. This will stabilize the test and prevent the grid heaters from stealing power and fouling the measurement. Just after your drive leave the engine run and test now. This should be a stable test then.
It’s worse now. The rpm is surging pretty bad, enough that I can’t drive it safely.
My current alternator is 5 years old now maybe I should throw a new one on.
Any recommendations on that or will a parts house one suffice?
Test for AC noise. Now that you’ve done the W-T mod it could be ok. Once I got my Nations alternator I still had the lock unlock issue with my transmission. Once I did the W-T mod I haven’t had any issues. I did the mod 5 or 6 years ago. It’s the high  AC noise that fries the computers.
I have the 6spd but I’ll look into Nations. Had a good run of 24 years but I guess it’s just 2nd gen luck!
I did the wt mod 2 years ago I never had issues up till then but it seemed like a good idea to just do it.
Ya I hear you. Ya the autos tend to give you a little warning before the AC noise takes out the Ecm or in an autos case pcm to.
I believe that should be below .050 volts AC, or below 50 milli-volts AC.
From Moparman's video:
- John
- John
Edited by Tractorman
I ordered a Nations 180amp alternator.
When I was moving my truck into my works yard the rpm was going crazy and the “check gauges” light came on.
I hope other components arent getting killed by this thing.
Edited by Mace
Not sure if it will help but, check the alternator grounding that goes thru the mounting bracket. The pivot bolt gets corrosion on the bolt head and bracket. I ran a separate ground from alt housing to the passenger battery. Also check make sure you eliminated the factory grey connection clip on that ground wire to the passenger battery. I think it goes to the PCM if not mistaken. That grey connector is P.O.S.
WT wants that connector removed and solder the wire together.
I completed every aspect of the wt mod as written. That ground is soldered now.
Thats good :thumb1: see if you have resistance on the alt ground or run your own ground Alt frame to the ground post on the battery. I used one of the Alt housing screws and heavy gauge wire to the neg on the battery. Done this to both my 2nd gens.
I reused that grey connector from the ECM ground as my additional ground to the battery on the driver side. Looks pretty factory except for the ring terminal on the driver-side battery.
My ecm & pcm are in @Tractorman care and he’s forwarding it to ACS on Monday as well.
I’ve installed my Airdog 100-5G during the week. Quite happy with the install (I’ve deleted the oem filter housing now). I put a 6.7 wif sensor in the water separator and made a jumper harness from the engine harness wif connector so I can retain that. I’ve lost the heater side since I couldn’t find a filter with a heater element in it. One thing I noticed in the airdog harness is it uses the oem lift pump connector for the relay trigger and already comes with a diode suppressing relay.
I removed the oem lift pump & plate and am waiting on a Fleece block off plate to cover the hole.
During my adventures in wiring down on the engine harness I was leaning on top on the engine and accidentally broke the dipstick handle off. I see they discontinued it and have the “new style” dipstick & tube on order. The old tube came out surprisingly easy.
Just a note about my GDP Fuel Boss removal. I ended up breaking the crank side pulley wheel to gain access to the harmonic bolts to remove the adapter. Those set screws are a PITA to get out after many years of exposure to the elements. What a nightmare it will be if you had to replace a crank seal or something all because the set screws don’t want to come out.
If anyone is interested in buying my old kit I got a deal for you. You’ll just need a new pulley wheel adapter (I’m sure you can buy one from GDP) and new 3/8” hose.
Edited by Mace
Should of kept it. You just ditched a good fuel heater and a secondary filter.
Well it’s repaired and being mailed back to John tomorrow.  Here’s what they emailed me saying what they did. They didn’t come up with a cause. What a nightmare this has been.
“Problem Description and Diagnostic Trouble Codes (DTCs): P0606, P0113, P0118, P0121, and P0123
ECM Tests Results and Faults Found:
• No Communication to Lift Pump
• Lift Pump and APP Circuit in Short
• Cold Solder Joints on CPU
• No 5v Reference for Sensors
• No 9.5v Reference for Lift Pump
• Bad Wait to Start Light
• P0606 Code Present
ECM Repair Completed:
• Replaced APP (Accelerator Pedal Position) Circuit. Please keep in mind this Circuit shares a Ground Circuit with additional Sensors and any one of them could be in Short (MAP (Manifold Absolute Pressure) Sensor, Camshaft Sensor, Water in Fuel Sensor, Engine Coolant Temp Sensor, Intake Air Temp Sensor and Oil Pressure Sensor. Please see the attached diagram.)
• Replaced Lift Pump Circuit and Flash Chip
• Replaced 5 Volt Driver and 9.5 Volt Driver
• Resoldered CPU and 50 Pins
• Updated Software
• Replaced Wait to Start Light Circuit
• Removed P0606 Code (Prior to installing the Rebuilt or Remanufactured ECU, you must replace both Batteries, Terminals, and clean ALL Grounds. Failure to do so will result in the P0600 Code returning and voiding your Warranty.)
PCM Tests Results and Faults Found:
• Cold solder joints (on CPU, Flash Chip, and Noise Filters)
• Faulty Capacitors
• Low Volt Reference
PCM Repairs Completed:
• Replaced Capacitors (220uf 35v Capacitors (x3))
• Resoldered Noise Filters, CPU, and INTEL FLASH CHIP”
That thing was smoked! Should run like a top now.
  • 3 weeks later...
Just an update:
I got my items back today finally. I reinstalled the ecm & pcm but my troubles aren’t gone yet.
The engine runs but stumbles and falls to idle when I rev it up. As soon as I first started it the CEL was on, checked the codes with a OBD2 reader and I have an active P0122.
I did do the apps reset, checked ac noise (0.021 VAC). I may need a new apps.
Second issue: the wif light stays on, even with it unplugged at the engine harness it doesn’t go out. Not sure yet how to troubleshoot this one. This wasn’t a problem before.
The new airdog works great. However, if I key on (engine off) the voltage reading at the oem lift pump connector (that triggers the airdog relay) is about 8.9 VDC, when I start the engine it goes up to about 14 VDC and the airdog runs and everything is fine that way.
Welp.
Shoot the WIF plug with brake clean. Then bag the end and zip tie. Any moisture or oil will cause the light to come on. Typically I always leave the stock filter in place and get the big line kit from @dieselautopower. This way you don't have this issue, manifold coolant heat will warm the fuel up.
