2006 Transplant no start
- Replies 16
- Views 4.1k
Heavyd1980 4 posts
AH64ID 3 posts
guesswho512 2 posts
Rogan 2 posts
HELP!!! I've tranplanted a 2006 HPCR into a 2000 Ford Excursion 4x4 with an Allison 1000 5-speed and I CANNOT get it to fire. Anyone got any ideas? I had Bob Wagner (Smarty) program the ECU to shut off the SKIM requirement and make it into a "stickshift" so I can run the Allison TCM as a stand alone. I have 90hp injector tips, a modified cam and have bypassed all the wiring I can think of just to eliminate potential problems so I can get it running, but it simply will NOT fire without a shot of NO-NO fluid, but will not keep running. Once the ether is gone, no fire, period. Also, it appears that the oil pump is losing it's prime if it sits overnight and won't pump oil up to the rockers without forcing oil into the turbo oil feed tube first. Any ideas and suggestions short of shoving it off a cliff would be appreciated. Thanks in advance- steve "dieselclam holmes
