New Batteries
Just took my truck to the voltex battery today and had new batteries installed, I figured its about time the old ones were 6 years old and weak. They put it 2 of the 65 group size blems (2nds) for $35.00 each, left there with $75.00 out the door with a 1 year warranty . I work at advance auto parts, part time and they are $90.00 each with my discount. If anyone has a battery store that sell blems that will save you a lot of money.
  • Replies 12
  • Views 4k
I've been getting mine (also group 65) from Costco and they have a 100 mo prorated warrenty. The set I just replaced was just 5years old and starting to get a little weak. Took them in and they gave me 40% of the purchase price back. Then I got two new ones and the old ones were the cores (no core charge). By the way when you take them back they don't test them or argue with you, just give you your refund. Jim
Just replaced my OEM batts in the 02 120k miles, in cold weather they were getting weak and after cold startups in the morning it would intermittantly miss until the grids quit cycling. This issue was cured with the new batts.:thumbup2: Had a hunch about it and it was a good one as I proved my hunch true after knowing the miss is now gone during cold starts. Figured the alt couldn't keep up with draw and the voltage to the vp44 was getting low causing a miss.
I am still running my OEM batteries. (knock on wood) I am gonna try to get one more year out of them.
Must be nice to live in "Mason/Dickhead" Land!!!! Ain't no way in "Sam Hell" you could get away with that up here!!!!:2cents: Here's to hoping you don't make it!!!!!:lmao::lmao2::evilgrin: Major sarcasm implied incase the smilies don't get it across!!!
If you use one of these pretty regular, you can pretty much double the life of your batteries: http://www.ctek.com/EN-US/consumer/mus-7002.aspx
What is "GROUP 65" :shrug:...i just bought 1-new Exide 995 CCA and getting ready to buy 1-more. nned to make sure i get the right one's Richie
Richie
There should be a sticker on your battery giving the group size.
Battery Council International group size (BCI) specifies a battery's physical dimensions, such as length, width, and height. These groups are determined by the Battery Council International organization.
I just pulled the 65's off and put 27's on mine. The 65's are shorter all around than the 27's except they are a little wider and the battery hold downs dont fit them good. Our trucks came with 27's oem. Most places try to sell you 65's because they are cheaper but I would get 27's.
Here is a 27 (left) and 65 side by side
Posted Image
27 measures just under 7 inches
Posted Image
65 measure 7 1/4
Posted Image
  • 4 weeks later...
I've had real good luck with the Walmart batteries. I bought two new ones when I lived in Arizona. I had to replace them after three years in Ohio. They were exchange under warranty no questions asked. Just have you paperwork.
