Tire Air Pressure
If I step up to 285/75r16 tires in load range E what tire pressure should I be running. I know alot of you guys probably have this size.Thanks
  • Replies 23
  • Views 6.1k
I look at the profile of the tire and contact patch and base my pressure from that. Also using a tread depth gauge to double check to make sure I'm not over wearing the outside or middle of the tread and adjust accordingly.
i run 80 when towing and 65 when empty. also keep acheck on tread wear
