- Replies 11
- Views 3.9k
Mopar1973Man 3 posts
guesswho512 2 posts
Rogan 2 posts
jshmohr 1 post
Yesterday I had a horrible vibration while braking so when I got home I pulled the front tires and found my pads and rotors where shot. I've only had the truck a little over 6 months and never checked them (my fault).So, I went to NAPA and spent $250 on rotors, pads, seals, and grease. I started w/ the passengers side first since it was the worst. I cleaned and repacked the wheel bearings and installed the new rotor (my truck is 2WD). When I went to install the new pads and the caliper they simply would not fit. I compressed the piston in the caliper w/ a c-clamp as far as it would go and still couldn't get it to fit. Now I'm thinking my caliper is bad, the piston is scored or debris is in it and that's why the passengers side was the worse. So, I head to NAPA, they are closed, so now to O'Riely (my second choice). I pick up a new caliper, go home and still the same problem.Long story short I just got home from NAPA this morning. I took all the parts and had them double check. I've got all the right parts according to them. Their only suggestion was to install 7500 GVWR pads. I took the 7500 pads b/c we've got a winter storm coming and I want to get the truck off the jack stands and out of the driveway. Here's a list of the NAPA parts I purchased yesterday:Pads: ss-7339mRotor/Hub Assymb: 4886452Wheel Seals: 21756The pads they gave me today are p/n ss-7260mThe 7260 pads appear to be almost identical to the 7339 except the steel plate for the inboard pad isn't soild where it slides into the caliper and the pads are not as thick.The sticker in my door clearly states that the truck has a 8800 lb GVWR. Has anyone else had this issue? I'm at a loss as to what to do. There has to be a reason why they make two different rated pads and I'm afraid to drive the truck now (especially w/ a load) until I get this resolved. In the mean time I need to get it out of the way so my wife can get her car in the garage.Any help or advise is appreciated greatly.
