Tires: Federal Couragia MTs - review
- Replies 18
- Views 25k
AH64ID 5 posts
dorkweed 4 posts
Rogan 4 posts
Mopar1973Man 2 posts
So, I just bought some of these uncommon tires.. Thought I'd share some info on them. Review of the Federal Couragia M/T Tires The Federal Couragia MT tires are a good tire for the money if you are in the market for a semi aggressive tread design that offers above average traction in various conditions offroad will still maintaining a mostly quiet ride on the paved roads. The tread design offers good mud traction with the a combination of large, stepped and siped lugs spaced out by voids large enough to assist with the self cleaning of mud and debris. Aired down the 3-ply sidewalls flex good. Incorporated into the sidewalls are protected by a extra rubber compound on across it's sidewalls. In snow and sand this tire does a little better than average when compare to other mud terrain tires. Highway manners are better than expected from a mud tire with less than moderate noise level and with the assistance of sipes in the lugs has better traction on wet or icy roads than other MT tires without the benefits of sipes. Tread life is better than average. Cost is on the low side of mud terrain tires. Features Large aggressive shoulder lugs. Strong protection block on upper shoulder for exceptional bruise, impact, cut resistance and protection from other off-road hazards Uniquely designed incremental block edge improves clearance of dirt and sand for constant performance Uniquely designed radius of sub-grooves enhances off-road performance SRG (Sloped Radius Gradient) block design increases block stiffness, enhances performance, and delivers serious off-road traction Bar at bottom of groove clears mud and rock particles and provide ultimate off-road traction Deep shoulder lugs and sophisticated central blocks fulfill the most demanding requirements of off-road grip and steering control when used for on-road applications Specially formulated advanced tread compound resists cuts, chips and abrasions for long life and even wear Size availability:
§ = 2 ply sidewall ¥ = 3 ply sidewall ▼ = Currently under development
