What chip to run
I recently installed 4 gauges in my truck, new lift pump, new exhaust and new BHAF. I was running my "Super Chip" in my truck and noticed that my exhaust temp peaked a few times around the 1200+ range when I would step on it and had my Super Chip installed. I uninstalled my Super Chip and noticed a 400 degree drop in temp.Honestly, I dont need my Super Chip installed at all times other than either hauling my camper or pulling my tractor and I dont need it either pulling them when I am on level ground which is what most of the interstates by me are.So I am looking for a chip that I can flip on/off at a moments notice instead of programming my truck. My truck is an 2001 Cummins Quad Cab 4x4. Something that isnt going to cost me dearly too.:spend: I am still working on my "honey do list" from the recently added items mentioned above.:lmao:
  • Replies 17
  • Views 4k
If you didnt have guages, hands down a quadzilla adr, but since you have guages I would go with the ol edge comp, I seen them go for around $300-$400Sent from my mobile phone using tapatalk
If youre wanting a nice chip thats selectable and not an all out programmer then i would go with quadzilla xzt+ all the way.-Jordan-
I've had really great experience with my edge juice with attitude! Sent from my DROIDX using Tapatalk
x2 on the xzt. I got mine for $150 off craigslist. You can turn it off when you want and use it when you want. You don't tap the the pump so install is pretty easy. I have used all of the 65hp tuners and I think this one is the best for towing.
cajflynn,A lil of the mark here but you got me thinking, on Craigslist, how did you search that? In what section? Just bought a slide in camper from the list! Better deals there than ebay sometimes, more local too!Thanks,Dave:hyper:
cajflynn, A lil of the mark here but you got me thinking, on Craigslist, how did you search that? In what section? Just bought a slide in camper from the list! Better deals there than ebay sometimes, more local too! Thanks, Dave:hyper:
I googled "quad xzt 2001 craigslist" That was it.
I'm running XZT+ and a home made IAT fooler... toggle switches in the knee panel in the cab. I like the ability to turn them off when I want. I normally don't need the +65 hp on the xzt so run in the econo mode which is a slight boost in power. Seems to have a firmer shift also.
Just making the trip over to Lowman, ID (Kirkham Hotsprings) I got 14.13 MPG crossing the scales at 16,080# worth or load. Edge Comp on 5x5, IAT set to 143*F, and stock injectors (RV275 are out for repairs :rolleyes:)...
So maybe the "53" block might be ok for you. 10yrs old & 100K, not bad.We'll keep your fingers crossed! I was under my truck looking for the 53 on mine. I didn't see after i got done putting in my crank sensor. I'mpulling a small 2 horse trailer & a slide in camper, tailgating for a football game today. No drinking for me, I'm the DD. Thanks again, Dave
I've been trying but no luck yet! Thanks, Dave:thumb1:
I think that is 1 million not 100k miles.
If 99K is 99,000 what is 100,000? Not sure myslf now!:doh:
Moved to Edge Juice after the EZ (@ 315K) melted.W/no problem(s) set @ 2nd level.. excellent for towing.EXCELLENT Customer Service
100k In his sig it says 1,000,000 and ive seen the pic of his odometer as proof :lol: -Jordan-
  • 3 months later...
cajfylnn, I'm running almost same set-up just put j-hook in. Curious, how much stretch do have on the spring and how much boost did you get, instruction with mine real vague. Thanks for you time MEH
  • 4 weeks later...
I just wouldnt put the diablo power puck. I have not been impressed with it
