How do I correct uneven tire wear?
- Replies 22
- Views 6.9k
ISX 6 posts
mr.mindless 4 posts
Mopar1973Man 2 posts
dripley 2 posts
My back tires are bald in the centers which tells me overinflation which I do run 60-70psi in all the time, loaded or not. I know Mike has that calculator but I am not convinced it works seeing as how no load would mean no pressure. The front tires are bald on the insides, which tells me the springs are shot, which I'm sure they are lol. Airbags for the front was only $80 so I will get the front jacked up to fix that issue.However, how do you know where level is? If I jack the front up, how do I know when the tires are perfectly flat on the ground, not leaning to one side or the other? This should factor in tire pressure probably since more pressure will make the center of the tire protrude more than the rest of the tire.I am not looking for any guesswork, I want dead nuts accuracy on this issue. I have some theories on what to do but most of you have more experience than me so I'd like to hear what you guys have to offer.
