Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
I am going to adjust valves on my '02 and so far have the valve cover off, so far so good. Now I see that I need to move the engine to TDC which is noted on the pump gear housing. HELP...is this pump gear (with the indicator line) under the Crankcase Breather??? I have the hose off and can't seem to get the Crankcase Breather off if that's where the gear is located.Great pictures and help on the link here for adjusting valves but the part about the gear with the TDC mark was not shown. I have the Dodge Shop Manual on CD and it shows the breather as coming off....how do I get it off and if I do get it off, how do I get it back on securely? I hate to start prying on stuff and break it. Waiting for further instructions. Thanks.
