ScanGauge II Calibration Process
- Replies 13
- Views 6.5k
Mopar1973Man 5 posts
royta 3 posts
Dave3500 1 post
volkswagon 1 post
Ok Gang...I got the ScanGauge II dialed in perfectly and extremely accurate now. I know exactly how to do and make the adjustment so it right near perfect. Fillup Procedure.1. Pick a fuel station that you going to use for a calibration fill point.2. Pick a pump that you going to use for filling. You must return back to the very same pump in the same direction!3. Fill the tank on the lowest sped possible of the pump this reduces foaming of the fuel.4. When the pump shuts off. That's it! Hang up the nozzle! Don't round up to the nearest dollar...5. This you go through the fillup process but leave the setting alone. Don't change the offset percent. But you can change the price value!6. Drive the truck far amount of distance at least 1/2 tank to 3/4 of tank.7. Return back to your fuel station to the same pump in the same direction.8. Fill the tank again in the same manner. When the pump stops hang up the nozzle.9. Now do you fillup and change your offset gallons to match the pump. Now be smart If you get 18.889 Gallons make sure you round up on the ScanGauge II to 18.9 gallons. If the hundredth placement is less than 5 don't round up. Say it was 18.810 you would of set 18.8 gallons.Speed Procedure1. Use a GPS or barrow one from a friend.2. Take a ride with the MPH display up on the ScanGauge II and verify the speed is correct for all speed. (25, 35, 45, 55, 65, 75, etc.)3. If not correct your ScanGauge II speed to match the GPS (not the stock speedometer!).As for verification... :thumbup2:I went back now for the 3rd trip to the very same station filled up again. Same pump and same direction. The pump stopped exactly on the amount of gallons the ScanGauge II displayed. Not to mention the price was exact too. Just doesn't get any better than that!Failures...I've seen several people get upset about ScanGauge II not being accurate. Most of the time you find out they are using any old pump and rounding up to the nearest dollar. You must use the same pump for calibartion as I'm finding out even though all pump have a weights and measure sticker meaning they are calibrated but most pump are not absolutely exact. So Station A might be +0.1 Gallon off when you go to station B it might be -0.1 off. You must use the same pump. As for direction some of the station have a slope away from the pump so if you in a different direction then it might change the level of the tank! Direction is important too. As for the speed this is how ScanGauge II gets its mileage so if the speed is wrong then the MPG figure is wrong too. MPG = Speed (MPH) / Flow (GPH)For example19.6 MPG = 55 MPH / 2.80 GPH So if your flow calibration is done poorly then the flow number is skewed. If your speed calibration is done poorly so your mileage is skewed... So if both are poorly done well you going to be very upset to find out you hand math and ScanGauge II are a long ways from being close! Oh... If you do hand math to verify the ScanGauge use the miles from the ScanGauge not the odometer. Like on my truck I'm close but not exactly perfect on the speed I'm still off by 0.5 MPH so the Scan numbers are slightly off from hand math done with the odometer but the hand math of the ScanGauge II is fine...
