Front end popping noise?
- Replies 22
- Views 6.3k
Mopar1973Man 7 posts
volkswagon 5 posts
98whitelightnin 5 posts
Wild and Free 2 posts
Ok gang...
I've now got one I need to research and figure out. I've got a random front end popping noise that is hard to reproduce. Like I seem to be able to reproduce it the most getting in the driveway because of a few tight turns I've got to make and you can feel the pop in the floor on the drivers side. I jacked up the front end and looked everything over the best I could and didn't find any damaged parts.
Last fall
[*]Ball joints
[*]Track bar
Last summer
[*]Wheel bearings
Steering is tight and good condition but there is a good pop when it does it. Now the only thing I did find is the driver side fender is torn loose from the body in 2 places. So I'm wondering if the body flexing is causing the fender pop against the body metal?
