Im looking into a scan gauge its time with the price of fuel a friend has one and said it really helped out by letting him know how to drive with the right foot :lol: any thoughts on which one a nd were to buy from?
  • Replies 115
  • Views 23.3k
Mike, can you watch your engine coolant temp on the scangauge? If so, can you watch it next time you go out and see if it fluctuates and how much?
So, 3 fill-ups in, with my SG2, I'm around +43% fuel adjustment.. Average about 11.9 - 12.3mpg via SG2..Mike - what's this X-gauge setting stuff you keep talking about? What are YOU using it for? My gauge display (right now) is Instant MPG, AVG MPG, MPH, TCF.
Rogan, is your scangauge accurate on fuel consuption? Mine never is. When idling it will show very low gph. Seems to only be sort of accurate under load so no good when driving empty. I mainly use mine to watch IAT and ECT.
So, 3 fill-ups in, with my SG2, I'm around +43% fuel adjustment.. Average about 11.9 - 12.3mpg via SG2.. Mike - what's this X-gauge setting stuff you keep talking about? What are YOU using it for? My gauge display (right now) is Instant MPG, AVG MPG, MPH, TCF.
All right here... http://www.scangauge.com/support/x-gauge-commands/
Posted Image
Today, towing through rolling hillside.
Sent from my PC36100 using Tapatalk 2
Understood. I'm more interested in YOUR custom x-gauges and what they do ;)
Basically I've got Cmg (Current MPG for the day), Tmg (Total MPG's for the tank), Gfr (Gallons of Fuel Remaining), O2 (Oxygen sensor)I've got a few others but don't use them much or they never worked for my applications...So typically I leave these up on the display...MPH = SpeedCmg = Current MPG for the DayTmg = Total MPG for the TankMPG = Instant MPGSo what I do is keep my MPG above the goal MPG I want to to reach as much as possible. I use the knowledge of the terrain to aid me in reaching my goals. So like If I drive to McCall, ID I know that by the I reach there and climbing a 7% grade I'll have roughly 16-17 MPG. Then while in town I baby the throttle and keep my number as high as possible. I might gain another 1 MPG driving in town. Then on my way home I try to drive in a fashion to allow the truck to coast as much as possible gaining the whole way home. Hence my ability of reaching 23-24 MPG locally in the mountains. If you have to apply brake to make a corner and accelerate again your driving way too fast. Like travelling up and down Goose Creek grade I know the speed limit is 45 MPH. But the corners are 25 MPH (tight). So if I cruise at 35 MPH up the grade I'm not slowing and trying to build speed again (at least not as much).Like another stretch of road I travel from New Meadows, ID to Council, ID where it winds there the mountain I know its posted for 55 MPH but I typically drive it at 45-50 MPH because I can just about leave the cruise set and get around all the corners and never slow down.Anytime you use your brakes or exhaust brake you converting work energy into heat. So if you can drive in such a manner that you use just enough fuel to travel through a area without hitting the brakes you gain even more.In the state of Idaho there is no minimum speed limit. So you can drive slow as you wish but if you holding up more that 3 vehicles you must yield to traffic. (Pull over and let them pass). Since the economy is so poor up here there is so little traffic I can drive 35-70 miles and never have anyone pass me...
do you manually reset your Cmg and Tmg on a daily basis? As mine is currently, it resets MPG and Avg MPG every time the ignition is cycled.I'd like the Tmg and Cmg x-codes.. ;)I also try to feather the throttle as best I can, and as often as I can. I do not speed around, and I don't stab the throttle. I rarely go above 23-2400rpm now, during shifts, and I'll try to maintain 2200rpm while climbing any grades..Well, you see the results in the pic a few posts back.. :spend:
do you manually reset your Cmg and Tmg on a daily basis? As mine is currently, it resets MPG and Avg MPG every time the ignition is cycled. I'd like the Tmg and Cmg x-codes.. ;) I also try to feather the throttle as best I can, and as often as I can. I do not speed around, and I don't stab the throttle. I rarely go above 23-2400rpm now, during shifts, and I'll try to maintain 2200rpm while climbing any grades.. Well, you see the results in the pic a few posts back.. :spend:
I'll have to get my manual out and get the XGauge codes for you...
How about it's rare for me to get above 2K on the tach... Unless I'm hot dogging. :burnout2:
I do most grades at about 1,500 to 1,600 RPM's But if I'm towing I hold my RPM's at 2K...
It sure sounds like Rogain has "Frankenstein" shoes on when he drives!!!!:lmao::lmao2::2cents:http://forum.mopar1973man.com/threads/6086-3-In-a-Row I don't give a rats dupa how many folks pass me going down the road. Just as long as they don't endanger me by tail gaiting or passing me and then cutting in front of me to soon!!:smart: My last tank of fuel that got me 20+mpg, the Lie-O-Meter read 26mpg average for that tank. The tank I'm on now (no towing at all so far) is reading 28.8mpg average with 305+ miles on the tank and the fuel gauge is pegged right at 3/8th's tank of fuel used or IOW 5/8th's tank left!!!:thumbup2: All of those tanks got me 600+ miles on them also!!! And yes, my stock sized tires are calibrated correctly via my Smarty. Rogan, I think the raw egg under the accelerator pedal may be in order for you!!:smart:
I only rev to mid 2s when towing and rowing through the gears. I don't speed and my truck feels a little luggish if I stay below 2000 when shifting, especially when towing. The scan gauge said 14mpg today when cruising in 5th at 40.. no towing and flat ground. From the Galaxy S3
Posted Image
:wink:
Ok, so I don't drive like hell, not even remotely close to that. I really, really try to feather-foot the truck to save fuel. But no matter what I do or try, it makes little to no difference, towing or not..
http://forum.mopar1973man.com/attachment.php?attachmentid=4244&d=1341589031
http://forum.mopar1973man.com/attachment.php?attachmentid=4245&d=1341589173
pay no mind to the 6/4/12 fill-up being 414mi. it was a fudge-factor of not completely filling up, then adding more later that day to fill it up, so I kinda combined the two and made one entry.
