Torque Converter Lock / Unlock Issues
  • Popular Post
Ok Gang...I've got a for sure way to diagnose torque converter lock up issues where it lock and unlocks at about 45-50 MPH. I had a gent call me yesterday with this problem and he's replace both batteries, alternator and the APPS sensor. Attempted all the different wiring issues (adding ground, tinfoil etc.) nothing worked. Like I told him the truck ran 11 years without all this stuff and doesn't require any wiring change to make it work. What it needs is the damaged part to be replaced. So he's returned the wiring back to stock setup.Now I told him to unhook the alternator fuse and take it for a ride... Guess what... No problems! Even though he replaced the alternator it has a damaged diode in it and it bleeding AC noise into the electrical system.So before doing any wiring mods, tinfoil, adding grounds, adding filter... PLEASE! Bench test your alternator! This is the second time I've suggested this and both time resolved the torque converter lock up issue.
  • Replies 582
  • Views 221k
  • Here ya go!  After the rebuild as compared with the two meter pictures from above.   DC         AC Ripple     The read out   And finally ......wait for it.........drum roll........ T
    What is bugging me to no end is the fact there is all these wild write up of people adjusting APPS sensors, wiring mods, extra grounds, filters, etc. I still say the truck ran fine without any of thes
  • 6inarow-01
    6inarow-01
    Hey guys I believe I am the person Michael is talking about when he created this Thread... Seeing as how I replaced both batt. new alt., new apps sensor... took it to best diesel shop in town and they
Got my new alternator today.  Took a Bosch off and the replacement was a Denso.  After replacing the alternator, the test result was 0.00 to 0.015 VAC.
I will road test tomorrow.  I am pretty sure that solved the problem.  I did check the alternator brushes for the field and they were pretty well worn along with a lot of scoring and grooving on the slip rings.   Not sure if they contributed, but I am sure that didn't help anything either.
After 2 days of driving, the TC has stayed locked.  Looks like the problem is solved.  Time will confirm my results.
Thanks moparman
Pepsi71Ocean found that a bad set of slip ring brushes can create high AC noise issues as well so it might of been that as a cause too.
I am going to see if I can find a rebuild kit for the alternator.  Not worth paying the shipping costs for the core charge refund.
Thanks moparman
where did you get your denso? And how many amps, and price. Thanks.
I got it from http://allmoparparts.com/amp-parts/#parts
Make sure you have your VIN handy, they did check mine to make sure it would work on my truck.
Thanks moparman
It's been a couple of weeks, and everything is holding.  No instances of the torque converter unlocking.
According to this website there is only one alternator available fro our truck http://allmoparparts.com/amp-parts/#parts I'm guessing you got same one? This  part #5104772AA  So the one you got from this website was a Denso and now they want your core or $163.85 is no core and shipped to your door?
That is correct Pepsi71Ocean is right and I just confirmed it. I rebuilt my alternator last year and put new bearings, diode pack and new brushes, I did not changed slip rings and didn't realize just how worn they were till the other day. I decided to figure out why after rebuilding my alternator I still had around 0.05vac at idle and if revved up i could get it over 0.1vac. So I tried to use a small flat piece of hardened steel to get the edges rounded off and get grooves a bit smother (while it was on the truck and I could start it and get to slip rings while engine was running I was milling slip rings) , thinking it would be a lot better. After wasting about half an hour put it all back and my vac jumped from 0.05 to 0.12 at idle and 0.23 revved up. Maybe after it would all seat in new place it would come down but considering slip rings were most of the way wore, I went to local alternator place and got new slip rings for $10, took it all apart soldered it all back in place and what do you know 0.07-0.08vac on start up, then went for a ride about 10ml checked it again 0.03-0.05 vac and if I revved it up it didn't go past 0.05 where before it would get over 0.1 sometimes. So i'm hoping after some time when brushes wear to slip rings it would be down to 0.01-0.02vac. But the whole point of this, is that messing with slip rings and brushes does affect VAC. Even though diode pack should take care of it. Hope this wasn't too confusing. Tried to attach some pictures but wasn't able too.
Hopefully you are able to get pictures loaded, I'd be interested in seeing them.  Has anyone written an article on rebuilding an alternator?
I tried to in one of my posts, but i'm not a good article writer. I have few pictures of parts for Bosch alternator that's the one on my truck.  Tried loading pictures and the message I get is ( There was a problem processing the uploaded file. -200 )
The price is plus a core charge.  $50 core charge is added at checkout.  Shipping from here back to the east coast doesn't make it worth sending the core back for me.
Maybe you could list the part numbers and where you go the kit.
there was no part number on wear rings and the guy I got it from just went out back and got it of the shelf. Cost me $10 out the door. Just tried downloading pictures and still same arrow message.
  • 3 weeks later...
I have been absent on this for several years but decided to look at the the design of the 2010 APPS since Dodge is bound to fix the problem in the newer design.  Looking at page 14-125 of 2010 FSM they mention two APPS on the accelerator pedal with one APPS 1/2 the voltage of the other.  Then the circuit diagram on page 8W-30-24 shows the two APPS wired to the ECM.  I could not find the Theory of Operation on this but I guess that they have a "differential amplifier" in the ECU that takes the difference (differential amplifier) of the two signals such that equal noise on both signals cancels out. They use the 1/2 voltage route since a MINUS 5 Volt supply would otherwise be required for the second APPS. The noise would be equal on both signals for any ground resistance but usually twisted pair wire  is used so that any induced noise is also exactly equal and also cancels out. Telephone companies  have all used that for 100 years or more.
2nd generation owners obviously can not go to this extent so we are limited to noise filters, wrapping wire bundles in aluminum  foil,  adding beefier grounds, and making sure alternator diodes are all good. Whatever works for your situation. I use the noise filter(2010) and I had to double my capacitor value after four years to make it work again for me(2014).
I could not see the APPS signal passed onto the PCM (transmission shifting) as hardwired so I assume the Can Bus and processors are  faster so that it cal be passed on digitally over the serial link. Dodge designers seemed to be more worried about ground noise than induce crosstalk - no twisted pair. With no need  for a down shift cable to the 68RE  all electronic transmission they got rid of all cables - throttle and downshift.
Edited by balsip
If you have to put that much capacitance, you have voltage issues.  Ground, charging sys, somewhere.   After I redid my grounds and alternator I have had zero shifting or lockup issues.
Still amazes me how much people attempt to ignore AC noise issues and build some new hack APPS sensor. I still say time to test for AC noise if you have to modify.
After fighting Napa bull carp I dropped the money for a new denso alternator from dodge.
The part number is 5104762AA and the tc issues are gone.  However, my passenger side is reading .05-.06vac and the drivers side is .02-.03vac.  I'm going to have to further this with Mike.
The other chase right now is the vdrop testing of my ground cables. The passenger was .07vdc but the drivers side was .184vdc
Pepsi,
I think there is also some gains in replacing the + lead from the alternator to the battery with something thicker.  You may not see this at idle in your driveway, but on a cold winter day after a bad start and long idle with the lights and heater grid going, a resistance there could easily make some noise within the system.
The stock lead is not "diesel" sized, IMO, but I haven't done any math to prove it.
Edited by CSM
I have though of this as well. But I haven't really though of replacing it either.
  • 3 weeks later...
Hi everyone, im new here as a member but ive been following this topic for a while cause I too am having lockup issues, I first had it almost 3 years ago.. I got the BD noise isolator and that fixed it until earlier this year, I cleaned all grounds and replaced my terminals and the issue went away for about another month, then it came back, this time i replaced my alternator with a BRAND NEW one and it was fine for about 3 weeks, then it came back, i reset the tps and it was fine for about 2 weeks, then yesterday it started back up worst than ever.. i am at such a loss!! Tomorrow morning im taking it to a local auto electic shop to have them test the alternator specifically for diode failure. Maybe this new one went bad? If it turns out to be good im at a loss of what to do.. My truck is a 98.5
It's very possible that the brand new alternator is bad, I've seen it happen a lot. You could also try pulling the alternator fuse and see if the problem goes away.
