- Replies 28
- Views 6k
Mopar1973Man 9 posts
hex0rz 9 posts
Rogan 4 posts
dripley 3 posts
Okay, so I gave it some more thought about how I could go about adding a needle valve for my gauge. Instead of going the route of "in-line", I figured, I will just put a valve in on one of the ports thats on the fuel filter canister. Problem is, it seems like it cannot be done? What I mean is, I went to Home Depot and the guy did not have any of the right fittings. :banghead:The fitting for the fuel pressure gauge is an 1/8" Iron pipe thread. He did not have any valves in this style. Nor was he able to get any of the fittings he had to work.Do regular hardware stores have the right kind of needle valve I need or is it special order? Also, he mentioned his valves were a fibrous material and said they probably would get eat up by the diesel.
