- Replies 13
- Views 4k
SWATPARAMEDIC 5 posts
Mopar1973Man 2 posts
Rogan 2 posts
AH64ID 1 post
Not quite sure what the problem is, but here's what happened. I had cruise set at 75 and everything was fine, tuck ran fine, good oil pressure, plenty of power, no warning lights, etc. All of the sudden there was a clicking sounding type of a knock, for lack of a better description and a lot of bluish smoke I think, it was dark but I could see smoke in the mirrors. It would increase as the RPM's did. I got off the turnpike and called a wrecker. Checked the oil it was full and no puddles or leaks. I had my OBD II scanner with me and it read P0234 with no check engine light. As far as I can tell I think the engine sounds fine but the knock/click is so loud it's difficult to isolate. I don't have a fuel pressure gauge so I don't know what the pressure is but I have replaced the VP and the lift pump. Never had that noise before, nor have I had a blown turbo. Is it possible the turbo and or waste gate could be making the sound?
