- Replies 35
- Views 7.5k
RPM 17 posts
Mopar1973Man 6 posts
dripley 5 posts
98whitelightnin 2 posts
I've got a new one. I have the following codes; 0112 Intake Air Temp Sensor voltage low, 0230 Lift pump circuit out of range (This doesn't surprise me much as I took off the electric pump and have been running the mechanical pump for a few months now. Maybe I should have did something with the wires instead of just unplugging them), 0237 Manifold Air Pressure sensor voltage low, and 1475 Aux 5 volt supply voltage hi. The dead pedal affects the top speed. My acceleration sucks and it tops out about 55/60.Now I have heard 1475 is one of the codes that shows up when the ECM takes a dump but it accompanies codes from all the sensors and the alternator starts putting out crazy numbers. My alternator is charging at 14 volts and I just have the two sensors. Also The sensor voltage is low and the 1475 is the high side.A mechanic I know says Dodges have had an issue with the AC hi side pressure switch goes out and takes out the other sensors along that reference string. Since I have never heard of such a thing. I will check that tomorrow. Anyone have anything with this set of codes? And anyone know where the error code reference went? I can't find it.
