- Replies 20
- Views 4.9k
Mopar1973Man 5 posts
GuyWithA24Valve 3 posts
duesman 2 posts
I have a DiPricol mechanical gauge and had problems with the isolator, replace that with the needle valve set-up as decribed on this site. I still have the gauge dropping from about 15psi to ZERO and back up to 15. I've tried opening the valve more and closing it more with no change in the action of the gauge. You'd think that if the fuel pressure was truly dropping to zero the engine would let me know. Maybe it was the gauge all along and not the isolator?I'm going to replace the gauage and would like to install an electroinc unit to keep fuel out of the cab. I've seen there have been some problems with the electronics. Any suggestions on them and which seems to be best?Thanks.
