In Bed Fuel Access Hatch...
- Replies 13
- Views 2.1k
JAG1 5 posts
Mopar1973Man 3 posts
dripley 2 posts
Texas CTD 1 post
Today I decided in spite of the existing truck bed cross member above the fuel module, I cut the opening for a access hatch or lid, whatever you call it.I knew I was taking a risk in weakening the bed but, If I just cut the surface out first I knew I would then be committed:cookoo: Committed to getting it done and to get it right.I only cut the surface and removed that first. Then I was able to see what to do, especially with new light on the situation.I found the cross member just behind the module on the right side would allow 1 1/2'' square tubing over the top and support the cut bed frame just perfectly.After Easter celebration I'll figure out the rest the support needed and report back.As for now I know that 1/4'' thick diamond plate hatch door will fit perfectly flush and Getting that on Monday.
