ball joint press questions
- Replies 11
- Views 4.4k
Mopar1973Man 2 posts
Dave3500 2 posts
dripley 2 posts
CUMMINSDIESELPWR 1 post
will need to attack the balljoints on the 2000 ram, and I figured with the '98 probably needing it too, I'd snag a press and kit for removing/installing.Well, turns out the 2000 and up (until the AAM axle came out) uses a different set of tooling than the 1999 and down! What changed in those years? Mikes thread (the one that almost changed his friends' gender)
said he 'got by' with the harbor freight press. Are most presses like this (getting by?) or is there something out there resonable priced, and effective?Seen several with the tooling that is 'close' but not perfect.. And I know that even the best made tool still will struggle under the worst case situation! Anyone have 'generally good luck' with a particular set?I'D sure hate to post 'before and after' pics of my various body parts!
