Replaced one wire on the starter. Now truck will not start, no click at key turn.
- Replies 30
- Views 7.8k
jshalala 9 posts
bjytech 7 posts
Mopar1973Man 2 posts
bry1216 2 posts
Hey guys.
2001 2500 24v 6speed manual.
Always has started perfect and fast.
I noticed a very loose wire on the starter yesterday (the smaller wire).
I was going to pull the wire off, strip it down a little then reinstall it to get a better connection.
I wasnt thinking when I first got under it with pliers to loosen the nut. I must of touched something together because I got a spark and a loud noise. Almost like it tried to turn over.
Disconnected the batteries so that wouldn't happen again. Pulled the wire off, stripped it down to good wire, wound it around the grounding post and tightened a nut down on it.
Reattached the batteries, turn the key to start, all the lights come on, accessories work, etc.
But when I turn the key to start I get nothing though, not even a click. Did I fry something when I touched the starter with pliers?
I checked all connections, they look good. I can't tell if my relay is good.
Is there anyway I can jump the starter from underneath to see if it is still good?
The starter is nearly brand new from auto zone, but I noticed as I was trying to remove the nut on the mounting post for the smaller wire the mounting post was just turning. Like it was loose inside the starter?
I just replaced the starter relay, and 40 amp solenoid fuse 20 min ago, still nothing, not even a click. Once again all accessories work, WTS light works, etc.
What did I do?
Thanks guys
