Cooling system not able to keep up
- Replies 25
- Views 3.2k
joecool911 6 posts
Mopar1973Man 4 posts
JOHNFAK 3 posts
dripley 3 posts
On the final leg of my journey to our campsite while towing my travel trailer the engine temperature climbed up to about 220. The mark between 190 and 240 on the dash gauge. We were on a paved road, so no low range 4x4 was utilized. The grade was very steep and I was in second gear at about 2,000 RPM's. When I got to the top the temp reading for the engine was about 220. Smelled hot too. No gauges to monitor EGT's, etc so I cannot comment on that. So I put the truck in neutral and ran up the RPM's to about 1,500 until it came back to normal operating temp. Is this typical or should I be looking for an issue?
