recentering steering wheel?
- Replies 17
- Views 4.8k
dennhop 4 posts
Mopar1973Man 2 posts
CUMMINSDIESELPWR 2 posts
rdsutton 2 posts
So its been busy this weekend...ball joints Friday and Saturday. First time I've ever done them, wasn't horrible once I figured it out, but having to take the hubs apart to get to them was a PITA!!!! I want to know if a 2001 outer knuckle will fit on a 96 axle....Then, the Redhead steering box showed up on Saturday. I really didn't want to jump right back into it after dealing with ball joints for about 15 hours total, Friday and Saturday, but since losing my brakes and steering due to vacuum has become a daily occurrence, I dove into it today. Replaced the steering gearbox, rebuilt the vacuum pump (twice, since I put a seal in wrong the first time, replaced the lower steering pump, and added the Dodge steering brace. I also, while driving in the top bolt on the gearbox with the impact, ran the tip of the bolt into the fitting on my low pressure line...which was pinched between the bolt and the gearbox.:banghead: luckily, Advanced had a low pressure line with the right sized fitting...don't know what vehicle it was supposed to go to, bit I can tell you it wasn't for a 96 Dodge Ram 3500!
So, now the steering is tight, super responsive-I'm gonna have to get used to driving a truck that actually steers when I turn the wheel! That all being said, my steering wheel is still off to the right...and its bugging the crap out of me! What's the best way to adjust that? Drag link, or other?
