- Replies 13
- Views 6.6k
JAG1 4 posts
CSM 3 posts
Mopar1973Man 2 posts
98whitelightnin 2 posts
I know there has been talk about how few times an ECM goes out, not to worry about the engine heat and where it's mounted and so on. Except isn't it getting harder to find a good reliable one? Getting it flashed properly can be a problem also, I've heard. Then you have a few ECM rebuilders/ repair companies sending off faulty units. Sometimes being a crap shoot trying to get a good one. Some have reported bad experiences while their truck sits for days sending units back and forth till they get one that works.Now I have been Googling engine heat, ECMS and problems... finding reports about how heat does affect them. One ECM supplier reporting that the engine heat is the biggest enemy to the ECM. On a truckers forum they discuss how to keep it cooler with running fuel lines near or around it. I think I remember reading how Cat engine already does this for their ECM's. On the Cummins forum there was a guy complaining about his 24 valve was acting up always after it was up to full engine temps. He then moved the ECM off and away from the engine, mounting it on the original fuel pump bracket no longer used and his trouble went away.So if you are like me and want reliability for the long haul doesn't make sense to move the ECM away from the block? I'm wondering too, if I can ground the ECM housing directly to the battery after it's moved?Thanks for any thoughts
