- Replies 13
- Views 2k
Mopar1973Man 4 posts
diesel4life 2 posts
oldbeek 2 posts
gassernomore 1 post
Installed raptor 100 about one month ago fuel pressure changes about every three days and has to be adjusted Up or down 3-4psi is this a problem with the raptor? If the screen on the inlet is clogged would it pump 42oz fuel at the vp in one cycle? When you set fuel pressure at 17psi at idle wot is 13 is that normal? Thanks Ed
