Gauge Install
So I finally ordered and installed my gauges. I got Isspro EV2 Black Face gauges, 0-30psi Fuel Pressure, 0-1600* Pyro, 0-100psi Boost. Installed and working minus the fuel pressure gauge. I just got the last piece of that puzzle so tomorrow that will be totally functional. After I grew the cahoneys to drill a hole in my exhaust manifold it was cake work. I spent a lot of time running my wires to keep them clean looking and safe. Spent a lot of time cutting and fitting my stock a-pillar cover to get the gauge pod to fit nice and flush and as close to factory as possible. I hate when people do sloppy installs. But they look great!Pics to come soon!!:ahhh:
  • Replies 11
  • Views 10.6k
100 PSI boost gauge is no fun -- You gotta see that needle actually move. :lmao:
I thought I ordered 0-60 PSI but I apparently was wrong. LOL. I'm gonna e-mail Geno's and see if I can replace just the gauge, I don't wanna ordr a whole kit or remove my installed one lol.
I cant get myself to drill in my exhaust manifold either I've had the thermocouple sitting on my desk since July! Did u take ur turbo off? Any tips?Sent from my RM-820_nam_att_100 using Tapatalk
I've lost count now how many manifolds I've drilled through. What I always do is get a magnet, a rag, some grease and the bits. Start with a center punch to keep the bits from walking (Make sure you center the hole correctly on the back half of the manifold, as there is a divider between the front and rear half on the stock horns!) start out with a tiny pilot hole, using a drill bit dipped in standard grease, to collect any shavings. I drilled a bit, stopped, cleaned the grease off the bit with the rag, and regreased the bit. Once I had the pilot hole drilled, I cleaned up the manifold with the rag, and then moved on to the larger bit, doing the same thing, grease the bit, drill a bit, clean it off, and regrease, until I was all the way through. With the bit still in the hole, I wiped down the manifold, to get any big chunks out, and then pulled the bit out. Tapping the hole for the 1/8 NPT thread was the same-dip the tap into the grease, and tap, cleaning it out periodically, till the hole is tapped appropriately. thread in the probe base, and you're good! I've used a flashlight on the first couple I did, to look into the hole, and there were no shavings inside the manifold, when I did it that way. Never had an issue with any turbos since then, so I know the method works fine.Another way to do it is to wait till the engine is cold, start it, and drill through with the engine running, to blow any shavings out of the hole while you're drilling it...I haven't done it this way myself, but there are guys out there who do and they've had the same success this way that I have with the engine off.
I sweated it also, but there is really nothing to it, just drilling a hole. I stuck a rag in the manifold behind the hole, drilled it and pulled the rag out and moved on. That was 7 years ago and no problems since.
Alright u all have given me the confidence boost I needed. Gona check this off the list this weekend! Lol :-)Sent from my RM-820_nam_att_100 using Tapatalk
I took me two beers and about 30 minutes of build up to drill the hole lol. But just keep the drill bit greased so it catches most of the big shavings. Same as the tap. Then stick a magnet down the hole a few times and clean out the shavings. From what I read on another forum any tiny shavings left in the hole will blow through the exhaust before the turbo even has time to start spinning. I believe that was from thouroghbred diesels site not another forum.
Grease, magnets, and a prayer. :lol:It was WAY easier than I thought it would be...
Well heres the picspost-12869-138698211443_thumb.jpgEGT Probe in manifold. 2" from flange, 5/8" towards firewall.post-12869-138698211453_thumb.jpgBoost bolt and sensorpost-12869-138698211463_thumb.jpgWires all nice and neat in baypost-12869-138698211472_thumb.jpgFuel pressure sensor in 1/2" fuel line fed from Air Dog 165post-12869-138698211486_thumb.jpgAll the gauges in their new home
