Head gasket boost leak?
- Replies 7
- Views 7.9k
MnTom 1 post
Wild and Free 1 post
JOHNFAK 1 post
mopartechnician 1 post
Around 2000 rpm upon acceleration it sounds like I have a boost leak coming from the back of the engine in the center of my dash. The head gasket isn't noticeably leaking anywhere and my coolant level is good. I replaced the intake horn gaskets, intake manifold gasket and put new intercooler boots on. I'm thinking the head is lifting, due in part because I swapped my HY35 for WH1C with an aftermarket wastegate set at 35 psi. And no gauges...yet...maybe it's just more air sound I don't know, wastegate?. Any thoughts?
