What are you guys getting for oil pressure?
- Replies 19
- Views 9.5k
Mopar1973Man 4 posts
ISX 3 posts
guesswho512 2 posts
flman 2 posts
I know the 98+ trucks are idiot gauges and the 97- trucks are supposed to have "real" readings but what exactly are your alls gauges saying? And for those of you with mechanical gauges, what do they say in comparison to stock gauge? I started my truck up and got 90psi at around 800rpm, and 35F engine block. As it warmed up I was seeing lower numbers and after running a few minutes was down in the 70's. As you can see, the gauge in the cab hardly moved, and of course is no where near actual pressures..
