- Replies 22
- Views 6.6k
mulcher812 5 posts
rseabur 5 posts
volkswagon 2 posts
CTcummins24V 2 posts
Put an hx on a couple of weeks ago and not impressed with it campared to the hy. Am I missing something? I had a turnbuckle on the hy and have the edge boost elbow on the hx. The Hx seems to be a lot slower boosting up, running hotter and taking a lot longer to get down to 350 for shutdown. All of this while driving empty. Will it perform better under load? I am concerned for when I put the 13000 lb fifth wheel behind it. While cruising at 60 empty I am at 5lb boost and running around 750-800 with the juice on 3x5. Seems hot to me. The hy was around 7lb boost and 700 if I remember correctly. I am not see the advantages. I am wanting to get some rv's or some +50 injectors also. What are your thoughts?
