Lost 4-5 mpg overnight
- Replies 11
- Views 2.9k
FlatTwin 4 posts
dorkweed 2 posts
gassernomore 2 posts
Freelancer88 1 post
Gents,Have been slowly upgrading my 2500 Cummins and getting it the way it should be. With everyone's assistance it now has a full set of gauges and a Raptor LP and drawstraw. Using a Edge/Attitude but its pretty much there just for the gauges. The wire to the VP44 is not even hooked up so running at level 1. Had the truck for a year or so and know it pretty well. Was getting 23-24 mpg on the overhead gauge in town, and 26-27 on the highway. No towing, running 60-65 or so, usually not faster. Did some work over in SoCal recently so filled up on the Arizona side of the border ($2.72!) and headed home. Did 670 miles before filling up again and it took 27 gallons. Overhead display showed 23.5 mixed city and highway driving. Actual MPG reading using a calculator was better, showing 24.5 or so. Was very happy with that. This is the mileage I have gotten for the last year I have had the truck.Took the truck to get an oil change at a place I have used for years a month ago. Very good guys. Changed the oil and rotated the tires, nothing else done to the truck. Mileage has now dropped overnight to 22.5 for either highway or city driving. Checked the two month old air filter and it looks great, and the "bypass" gauge on the filter housing confirms that. Air pressure in the tires is fine, running 14-17 psi fuel pressure. All other readings appear to be exactly the same as before. Fuel filter is 3 months old at most.Anyone have any suggestions on what this could be? Just took the truck back to the shop and they found nothing. Front tire pressure was a bit low but thats it.Looking everything over closely the rear brakes were pretty far gone so now have new pads in there but that does not appear to have caused anything with the fuel mileage. Cannot figure out anything else unless my VP44 is giving up the ghost but do not feel that something like this would happen overnight like this. Thx,Joe (FT)
