- Replies 17
- Views 3.8k
AH64ID 5 posts
lcattin 4 posts
Yankneck696 3 posts
dorkweed 2 posts
I have a 1999 dodge 3500 1 ton cummins. I would like to add an EGT gauge. The problem is that at one time the exhaust manifold cracked. The PO had it welded ( it apprears they did a good job). The weld is right through the center of where the recommended spot is to drill and tap for the probe. Is there an alternate location where the probe could be located? I really don't know if I want to take the chance of drilling where the crack was.
