Hard starts and weird tach
- Replies 40
- Views 7.2k
Nathan Croxton 16 posts
mopartechnician 11 posts
CTcummins24V 5 posts
CUMMINSDIESELPWR 2 posts
As of lately my truck has become hard to start. It requires about two ten second cranks to fire but then runs great. I have checked for fuel leaks and tightness of fuel components. I installed a lift pump and new lines 9 months ago. Also the tach doesn't match the speed you are driving. At light acceleration the rpms will jump all the way to 2k and on the highway at 60 mph it usually stays around 2700 rpm. I am not sure if it would be the crank sensor since I have no codes. The hard starting just happened out of the blue a couple weeks ago. Any help would great.
