New injectors now starting takes a little longer
- Replies 30
- Views 6.5k
Geo Garet 10 posts
Dieselfuture 8 posts
Mopar1973Man 3 posts
MnTom 2 posts
Install some DAP 7x.009 injectors. Everything went smooth and took my time checking everything. Tightened everything to spec's. Bled the system after installing and she cranked right up. Nothing leaks but now after sitting over night I have to crank on it a good minute or so to get it started. Before I couldn't hardly get my hand on the key and it would be running. At first I thought it may be some air in the system still seeking higher ground but after a couple weeks Im starting to wonder if maybe it's something else. I cleaned everything good and also put new orings on the crossovers. Any ideas on what else I should look for.
Also have fass lift pump 17 at idle and never below 14-14.5. After first start it during the day starts good there after. Just sitting over night causes the problems. Thanks
