01 Cummins auto Stalls when put into gear
- Replies 16
- Views 17.7k
CTcummins24V 3 posts
Chad3304 3 posts
mulcher812 2 posts
Dynamic 2 posts
Hello,
I have a 01 cummins auto, only mods are 75Hp injectors, and a fass. I just had a new injection pump installed, however the problem was there before this. When the truck is put into gear from P or N, it stalls. It will fire right back up, and when you get it to stay running, it acts as if it's under a load. When put back into park from Drive or reverse if it stays running, the RPM's jump up as if I tapped the throttle. Anyone know what this could be? Thanks in advance!
