- Replies 39
- Views 35.2k
Scuba64 12 posts
dripley 5 posts
Mopar1973Man 4 posts
Spiegelmann 4 posts
Just a quick question. I know you said the lift pump is working fine. What kind of pressure is it putting out? Needs to be around 14psi min and 20psi max. If not, damage can occur to the Injection pum
Neither do. The only thing that cleans the system is a quality fuel filter. If you want to clean your injectors you have to remove them and disassemble each one and clean by hand. T
Dripley, you shouldn't be passing and doing 90 with that 80 ft. long fifth wheel.
Hello all....
I have a 99 2500 Auto 4x4.....I just killed my in tank factory lift pump after 340km it in turn killed my reman IP...
I installed a Bosche IP Unit I had on stand by....I cycled the Lift pump 4 times at 25 sec each, then with all 6 lines cracked at injector end I cranked.
Got good fuel squirt out of 4 5 6 holes,so i tightened them down...
Cranked again and got good fuel squirt at 2 so tightened it down.
3rd crank session I got fuel at 1 and 3.....so I tigtened them down
Cycled the Lift pump 2 cycles and started cranking to fire.....
No fire... No codes
After 3 plus hrs of continuos cranking I still have ZERO FIRE and Everything seems to check out
I have power to the IP, Ihave cracked lines several times and I get solid fuel, but not as High pressure as I would expect...?
Question I have.... pin 5 at IP is fuel shut off from ECM.....could this keep pressure low and not allow Injectors to be firing..?
If I clip this is it a hot or neg when key is in on position..?
supposed to be on the road yesterday...and I am still dead in the water....
Moparman I bounced some things off you last year when I replaced my 53 block with a 2001 engine....Ended up with crank sensor and tone ring out front at crank pulley...been running great till this.....
Please Call me if you have any input I will be away from computer till later....thanks,
John in Eugene,Oregon
541-232-9958
