Amsoil intake fail
Well, looks like my Amsoil can't hack it! I'm pretty dissapointed with this as I'd only read and heard good things about this filter before installing it, with the only failures or negative comments coming from a guy who was running twins. Either way, my truck has no tuning and exhaust only so it's hard to think that a truck in pretty much stock form could do this to a 'premium' air filter!
Anyone know a place I can pick up a BHAF on the cheap?!
  • Replies 26
  • Views 6.4k
If someone admits a mistake & makes it good...  it would be pretty hard to hold a grudge.  But I can not stand being lied to.
Besides the airbox...
a different dealer claimed truck showed no codes, after I paid $100 to have codes read.  I refused the intank fuel pump fix & had it taken to a diesel shop who read the codes & lift pump failure code.  The shop fixed a ground & had it running on the OEM lift pump.  I decided to do the Airdog lift pump anyway.
An independant shop broke my 7 pin trailer connector in the chanel iron rear bumper on my C30...  and concealed it.  I went to hook up my trailer & found the destroyed plug stuck back together.
I had the truck AC worked on...  required pulling the dash.  The rear sensor on my installed radart dection system ($1000 unit) never worked after it came back.  Likely they just yanked the custom wires despite my pointing out the zip ties to get extra length.
See Mopar Mike is out of work and look at all the complaints because of bad shops. I have my list of never go backs too.
Mike you could be on the computer in your own shop making big.... guys traveling from far away...... and you could drink coffee and tell your guys what to do. he he
Dream on... :cookoo: No one want to drive to Idaho. Especially where I live in the middle of nowhere.
Yes. It's true I walked away from the shop I was working with being I was having a disagreement with the shop owner. But I can do my own thing and run my own show. I've got plenty of people I can do work for.
Keep in mind the world is filling up with more bs. Source Automotive has guys coming all the way in from Texas for service.
On the other hand, how can you place a price on freedom. Work when you want.... drink beer when you want. Wish those darn emoticons would start working all the time.
That's why I opened my own shop 20 years ago.....I drink coffee when I want to.
Yes it's good to be able to keep the rat race far far away. Even if for a few moments.
 I enjoy work so much with a vacation between jobs, but, some are a bit bigger than I like.
