  • Replies 1.7k
  • Views 219.9k
  • All done
Will do. What about the boost elbow setting??
All of this "testing" is destroying my fuel mileage :shifty: At least it's not my DD anymore!
Don't look at fuel mileage while tuning :-)
So the boost elbow closed is routing more air thru the secondary turbine which is why it's working harder and the primary is making less boost. The pressure ratios are much closer and the primary is in a better ratio. P: 2.6:1 S: 2.3:1
IMHO you are just going to have higher drive pressure based on the turbine sizes, cam, and overall exhaust flow from all that fuel; however the difference is only 0.05:1 between the two WG settings so I would leave it with the secondary working harder and accept the 5 psi more drive on WOT high rpm runs.
We can, hopefully, tweak the DP with timing thou.
  • 3 weeks later...
Someone please help my find this oil leak. It's literally driving me INSANE!!!! Driver side where the outside edge of the block meets the bell housing adapter. I know it's not coming from the top end as everything dry above the bottom of the block. The pan gasket looks sealed as well so I'm at a loss.
Is it coming from the inside of the bell housing?
I've seen a TSB about using a bead of silicone sealant for the rear part of the pan. Did you use a sealant on the oil pan gasket? A light color block paint would of help seeing the path of othe oil leak. I think I've mention this before...:whistle2:
No, you can see where it originates from just below the starter area.
:shifty: No I didn't use any sealant. I'm going to be pissed if I have to drip this pan :ahhh:
I've got some daylight now so it'll be easier to see back in there. Even with the paint it's actually pretty easy to see most places :thumbup2:
Here's the pics again so people don't have to flip back and forth.
Edited by TFaoro
You really only have two options in that area.  Your rear main or the oil pan.  I would pull the starter and make sure the bell housing is clean, then ignore the oil pan leak til summer. :whistle:
CRAP!!!!!! At least I have a lift to work on now. It's dry as a bone on the inside of the bell housing.
I dorked up my front diff housing when I did it. I was a little stingy with the RTV.  I had a tiny channel that formed when I torqued it up.  I had to redo it and lost over a gallon of mobil 1 oil.
I'll be losing 3 gallons of full synthetic and have to figure how the F to get the pan out with the motor in.... ah hell might as well pull the whole thing out again!!!!!
My truck 2 years ago had a slight leak at the back of the oil pan and it looked very similar to your condition.
I loosened all of the oil pan bolts during one of my oil changes and then re-torqued all of the pan bolts back to (18ft/lb) per the factory sequence. I then drove the truck for a couple hundred miles and upon inspection there was no visible leak at the pan. However to be on the safe side I re-torqued all of the pan bolts per sequence again at (18.5ft/lb) to ensure a good seal.  It has been 15k since re-torque of the pan bolts and so far the leak has not returned.
Loosen the motor mounts and hoist the motor up a little bit. That's what I did when I replaced the pan gasket...and it still leaks! Stupid cross member!
I've got a vibration... Is there any way to differentiate it between the Tcase and Transmission?
Wasn't there a post on here with a picture showing that someone cut out the cross member to drop the oil pan.  After the job was done they bolted the cross member back in there?  C'mon, sounds like a great addition to the article to the data base!! :thumbup2:
Um....   mabe take the driveshafts off and get under there with a buddy running it.  Bring a stethoscope.
How's the tailshaft bushing?
Edited by CSM
If it was standard petroleum it wouldn't matter just do an oil change... :whistle2:
Very little movement. I would think it would start throwing oil out the back if the bushing was bad enough to make it vibrate.
The vibrating is so weird... 80 and higher it vibrates while in gear under any load or no load. Pop it out of gear and the vibration stops.
70-75 it vibrates some while in gear and under load but if you take it out of gear the vibration gets worse.
Too much power, heat, cold, and a bunch of other excuses I can't think of right now :lol:
Vibration sounds like something axle/suspension related... something is binding be it a pinion bearing, axle bearing, ?? And when you unload it it vibrates.
Not saying it can't be trans... but that would be pretty weird. If you're sure it's trans, then start looking for shavings in the oil.  Nothing in there moves that much without cutting stuff.
Now its a oil with the expense of full synthetic you got to dump because of a leak. Just like all synthetic oil users they won't let go of that expensive oil even when they need to. :rolleyes: So you got the choice of living with the leak and constantly adding oil to the engine (adding up cost) or dump the entire thing and fix the oil leak (another expensive oil change). Bad idea is trying to capture and reuse the oil. Too much risk in falling debris landing in your catch bucket/pan.
