COVID Deaths after being Vaccinated
I remember that... That was a fun time...
Funny part is I'm born and raised in California so I'm one of those goofy one. Might not see it, but still part of me. So now I really don't have a whole of room to talk.
Hydrobooster rebuild
Well gang I finally had my hydrobooster failed and started leaking out the output shaft. So I ordered on Friday and Pirate Jack's rebuild kit and put extra on freight getting the kit here fast. So hang in there there's more videos and write up as an article. Also there will be a track bar install soon too I'll do a video of the diagnosing of it.
Ummm. Maybe you'll have to see my new red and brown. As for catching something it must of be that polluted Cally water you were filling your RV with. Then camping out with all those goofy Californiaians. As for me the last time I had a cold is about 4 years ago. I'm rarely even sick.
Did you know it's possible to be come strile from the Vax? Did you know in the the US they are paying big money for un-vax sperm? Did you know the vax alters your DNA? Then as pointed out that the Vax could kill you. Those are enough reasons for me not take the stab. I've already seen friend that had the Vax still get seriously sick, hospital stays, and death.
Surging When Cold
Low pop pressures typically get smokey. Still running my 7 x 0.010 150 HP injectors popped at 320 bar are still clean burning. I've even tweaked my tune and lowered my oil temperature back to 163°F and 195°F coolant with 100°F outside temperature and lowered my EGTs again. Increased my MPGs again. Still running the stock HX35W turbo.
iQuad display stray numbers
@Quadzilla Power should be called out and see this.
Zero stabs here, zero covid...
Sudden mileage drop
Thor when I did the injectors I did what 6 random injectors that were not not pop tested and flow matched so when I ordered them I picked the +50HP injectors from @dieselautopower and did the crossover tubes because after 180k miles the crossover tubes are wore out internally. Ive seen several photos of crossover tubes after 150k miles that wore out from high pressure and fine particules pushed through. I chose the +50HP because they are the smallest injectors i could get flow matched. I even drove to @dieselautopower and pick the parts up in person. As for running no EGT issues, small 2 MPG gain over the 170k injectors i pulled out.
It had to happen
Yes its true I was raised in Mission Hills, CA (Outside of Los Angeles, CA). I lived there till I was 20 years old and moved to Idaho in 1990. Diesels is just the most resent thing I'm doing. I've done car stereos for about 5 years this included rebuilding cassette decks and stereo installs in vehicles. The I create Cloud 10 Computers and built and sold custom built computers for the local area this included setup for internet and networking as well on Windows I closed down that business in 2008 when the market crashed. Then I swapped to doing diesel work. I've been wrenching on diesel since I bought mine in 2002. Now the website spurs off another talent for Linux Servers and Linux Desktop setup. I could technically restart "Cloud 10 Computers" and go into Linux Desktops and Linux Server setups. I'm capable of both Debian (Ubuntu Linux) and RedHat (CentOS 7 Linux) Administration. Lets put it this way I've locked down this website so good the Server Admins at the hosting company can't even get in till I turn off a few things. Yup it secure! The Server Admin told me my setup is the best security they ever seen! I've built several personal PC on Linux and people love them because they NEVER fail, unlike Microsoft junk...
2002 Dodge Dakota AC/Heater Fan Issue
New blower motor is a must, then replace the blower resistor. As for getting cold air you need be recharged.
Edge comp box
Edge Comp are known for shutting down from extreme cold or heat. Yeah the face controls are known for that issue the little button switches tend to fail.
Fuel Article - AirDog Draw Straw Installation
Nope. AirDog I've got sitting in the shop is all new updated black hose rated for bio-diesel and no longer has that cracking hose jacket issue. Same with AirDog and Raptor as well. But if you got your warranty card filled in and sent in then there is lifetime warranty and they will send you a new pump head. Thanks... I will. Thank you as well. I'll keep doing what I can.
Airbag light, seatbelt control module?
Not a problem... POOF moved... Dealer is the only way I know to pull those codes to see what is going on. Maybe if someone has a Snap Scan Tool it might do it. Yeah that was only in the early series of the 24V 2nd Gen. 2001 should be without that seat beat module. That is ABS speed sensor plug. Double check the driver side to see if there is a wire running up from the wheel bearing. Typically there is a wiring loom near by with a plug for that sensor on the fender skirt right next to the shock tower.
Lift pump shuts off after engine starts
Being I'm in the process of installing an AirDog 150. The Draw Straw video is done. I should be working on the pump by tomorrow. Only if it not 108°F like today. Ugh.
2nd VP in 2 Weeks
Be aware all modules are VIN locked so if there is a mismatch of module VIN numbers weird thing start happening.
Pilothouse/RAM3500 build
Ummm... I'm going to need lot more funding to make that happen...
More common than you think. This is why I made the video and showed how I've been doing it all these years without any issues. You should NEVER cut the straw at a angle it will cause more issues than its worth. It should always be cut straight. PERIOD. If I was going to notch it I cut it straight then notch with a grinder really easy and not more than 1/8 of inch deep.
No...
P20B7 - (Diesel Exhaust Fluid) Reductant Pump Heater Control Circuit Low
P20B7 - (Diesel Exhaust Fluid) Reductant Pump Heater Control Circuit Low Theory of Operation The Powertrain Control Module (PCM) controls the DEF Heaters via datalink communication with the Diesel Exhaust Fluid Dosing Control Unit (DEF DCU - sometimes referred to as the Selective Catalytic Reduction (SCR) Module). The DEF DCU receives two voltage supplies: One from the SCR Relay1 (which is activated upon startup). And, the other is a fused B+ supply. The DEF Tank electric heater and DEF Line Heater power supply and ground circuits are wired directly to the DCU. The DEF Tank Heater is integrated into the DEF Supply Pump assembly and is not serviced separately. Activation of the DEF Supply Line and DEF Tank Heaters operate independent of each other. Line heating is based on the Ambient Temperature Sensor input and Tank heating is based on the DEF Tank Temperature Sensor value. Heating of the Line or Tank Heater is initiated when the corresponding temperature value is below -5°C (23°F). Heating is stopped when the corresponding temperature value goes above -4°C (24.8°F). The DEF Dosing Control Unit monitors these inputs and reports them to the Powertrain Control Module (PCM). The PCM will illuminate the MIL lamp after this diagnostic runs and fails. The PCM will turn off the MIL light when the monitor runs and passes in three consecutive key cycles. When Monitored: With the ignition on, while the SCR Module Heater is commanded off. Set Condition: The DEF Dosing Control Unit detects low voltage on the SCR Module Heater Supply circuit. Possible Causes SCR MODULE HEATER SUPPLY CIRCUIT SHORTED TO GROUND SCR MODULE HEATER SUPPLY CIRCUIT OPEN/HIGH RESISTANCE DEF DOSING CONTROL UNIT POWER DISTRIBUTION CENTER Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC- Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC NOTE: If DTC P21CA, P21CB, or P21CC are also active, diagnose and repair that DTC before continuing with this test procedure. 1. Turn the ignition on, engine not running. 2. With the scan tool, actuate the DEF Line Heater or Tank Heater Override Test. 3. With the scan tool, View DTCs. Is the DTC Active? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (F203) SCR MODULE HEATER SUPPLY CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Turn the ignition off. 2. Disconnect the PDC C5 harness connector. 3. Disconnect the DEF Dosing Control Unit C1 harness connector. 4. Measure the resistance of the (F203) SCR Module Heater Supply circuit between the PDC C5 harness connector and the DEF Dosing Control Unit C1 harness connector. Is the resistance below 5.0 Ohms? Yes • Go To 3 No • Repair the (F203) SCR Module Heater Supply circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 3. CHECK THE (Z905) SCR HEATER RELAY 1 GROUND CIRCUIT FOR AN OPEN/HIGH RESISTANCE 1. Measure for continuity between (Z905) SCR Heater Relay 1 Ground circuit between the PDC C5 harness connector and ground. Is there continuity between (Z905) SCR Heater Relay 1 Ground circuit and ground? Yes • Go To 4 No • Repair the (Z905) SCR Heater Relay 1 Ground circuit for an open or high resistance. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 4. CHECK THE (F203) SCR MODULE HEATER SUPPLY CIRCUIT FOR A SHORT TO GROUND 1. Measure the resistance between ground and the (F203) SCR Module Heater Supply circuit at the DEF Dosing Control Unit C1 harness connector. Is the resistance above 10k Ohms? Yes • Go To 5 No • Repair the (F203) SCR Module Heater Supply circuit for a short to ground. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 5. CHECK THE PDC OUTPUT 1. Reconnect the PDC C5 harness connector. 2. Turn the ignition on and start the engine. 3. Measure the voltage of the (F203) SCR Module Heater Supply circuit at the DEF Dosing Control Unit C1 harness connector. Is the voltage approximately equal to battery voltage? Yes • Replace the DEF Dosing Control Unit in accordance with the service information. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Check two fuses (F19-30A and F75-10A) in the PDC that both feed the SCR 1 (Heater) Relay for an open. Check the connectors at the DEF Dosing Control Unit and PDC for spread terminals causing an intermittent connection. If the fuses and connectors are good, replace the Power Distribution Center (PDC) in accordance with the Service Information. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
P07C0 - 00 - Input - Turbine Shaft Speed Sensor 1 Circuit High
P07C0 - 00 - Input - Turbine Shaft Speed Sensor 1 Circuit High For a complete TRANSMISSION wiring diagram, (refer to the Wiring Information) . Theory of Operation The purpose of the diagnostic is to check the turbine speed sensor circuit for electrical failures by continuously monitoring the sensor output circuit for voltage high, low, or open conditions. The turbine speed sensor is a Hall Effect sensor that has an output range that alternates between normal high and normal low voltages as the turbine tone wheel rotates. If the measured turbine speed sensor output circuit voltage is greater than or equal to a calibrated high threshold (circuit high) or is less than or equal to a calibrated low threshold (circuit low or open) for a calibrated amount of time, a DTC will set. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: TCM supply voltage is between 10 and 16 volts. Ignition switch Run position signal is detected via dedicated circuit to TCM. Engine speed (CAN Message) is greater than 550 rpm. There are no ignition switch failures. Set Conditions: • Input speed sensor circuit voltage is greater than or equal to 1.821 volts for less than 1 second. Possible Causes INPUT SPEED SENSOR SUPPLY (+) CIRCUIT SHORTED TO BATTERY VOLTAGE INPUT SPEED SENSOR SUPPLY (+) CIRCUIT SHORTED TO ANOTHER CIRCUIT INPUT SPEED SENSOR SIGNAL (-) CIRCUIT SHORTED TO BATTERY VOLTAGE INPUT SPEED SENSOR SIGNAL (-) CIRCUIT SHORTED TO ANOTHER CIRCUIT INPUT SPEED SENSOR TRANSMISSION CONTROL MODULE (TCM) Always perform the PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). 1. CHECK FOR AN ACTIVE DTC 1. Record the Event Data and Environmental Data. 2. With the scan tool, erase DTCs 3. Using the recorded Event and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 4. Read TCM DTCs. Did the DTC return? Yes • Go To 2 No • Go To 12 2. CHECK THE INPUT SPEED SENSOR 1. Turn the ignition off. 2. Connect diagnostic scan tool and confirm Input Speed Sensor A/D voltage. 3. Starts the engine. NOTE: It may be necessary to allow the vehicle to allow the vehicle to roll while in a driven gear to see the voltage switching. If necessary to perform this test with the vehicle not stationary, enlist the aid of another person to operate the vehicle while monitoring the scan tool. 4. Place the vehicle in gear. 5. Monitor the voltage value Input Speed Sensor A/D voltage. 6. Does the voltage switch voltage Hi and Lo continually? (HI Voltage Over 1.20V / LO Voltage Under 0.80V) Yes • Go To 3 No • Replace the Input Speed Sensor and the transmission internal wire harness in accordance with the SERVICE INFORMATION. (Refer to 21 - Transmission and Transfer Case/Automatic - AS69RC/SENSOR, Speed/Removal) . • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). 3. CHECK WIRING AND CONNECTIONS AT THE I-255 CONNECTOR 1. Turn the ignition off. 2. Disconnect and check the I-255 connector. 3. Inspect the harness connectors and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. 4. Using the schematics as a guide, inspect the wiring and connectors specific to this circuit. 5. Wiggle the wires while checking for shorted or open circuits. Were any problems found? Yes • Repair as necessary. • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). No • Go To 4 4. CHECK THE (T69) INPUT SPEED SENSOR SUPPLY (+) CIRCUIT FOR A SHORT TO ANOTHER CIRCUIT 1. Disconnect the I-255 harness connector. 2. Disconnect the Input Speed Sensor harness connector. 3. Check for continuity between circuit (T69) and all other circuits in the I-255 (Transmission Side) harness connector. Is there continuity between any other circuits and the (T69) Input Speed Sensor Supply (+) circuit? Yes • Repair the (T69) Input Speed Sensor Supply (+) circuit for a short to another circuit. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 5 5. CHECK THE (T52) INPUT SPEED SENSOR SIGNAL (-) CIRCUIT FOR A SHORT TO ANOTHER CIRCUIT 1. Disconnect the I-255 harness connector. 2. Disconnect the Input Speed Sensor harness connector. 3. Check for continuity between circuit (T52) and all other circuits in the I-255 (Transmission Side) harness connector. Is there continuity between any other circuits and the (T52) Input Speed Sensor Signal (-) circuit? Yes • Repair the (T52) Input Speed Sensor Signal (-) circuit for a short to another circuit. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 6 6. CHECK THE (T52) INPUT SPEED SENSOR SIGNAL (-) CIRCUIT FOR A SHORT TO VOLTAGE 1. Disconnect the I-255 connector. 2. Disconnect the Transmission Harness Pass Through Connector. 3. Turn the ignition switch to the RUN position, engine off. 4. Measure for voltage between chassis ground and the (T52) Input Speed Sensor Signal (-) circuit at the I-255 (Transmission Side) harness connector. Is there voltage present on (T52) Input Speed Sensor Signal (-) circuit? Yes • Repair the (T52) Input Speed Sensor Signal (-) circuit for a short to voltage. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 7 7. CHECK THE (T69) INPUT SPEED SENSOR SUPPLY (+) CIRCUIT FOR A SHORT TO VOLTAGE 1. Disconnect the I-255 connector. 2. Disconnect the Transmission Harness Pass Through Connector. 3. Turn the ignition switch to the RUN position, engine off. 4. Measure for voltage between chassis ground and the (T69) Input Speed Sensor Supply (+) circuit at the I-255 (Transmission Side) harness connector. Is there voltage present on (T69) Input Speed Sensor Supply (+) circuit? Yes • Repair the (T69) Input Speed Sensor Supply (+) circuit for a short to voltage. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 8 8. CHECK THE (T69) INPUT SPEED SENSOR SUPPLY (+) CIRCUIT FOR A SHORT TO VOLTAGE 1. Disconnect the I-255 connector. 2. Disconnect the TCM C-1 and C-2 harness connectors. 3. Turn the ignition switch to the RUN position, engine off. 4. Measure for voltage between chassis ground and the (T69) Input Speed Sensor Supply (+) circuit at the I-255 (TCM Side) harness connector. Is there voltage present on (T69) Input Speed Sensor Supply (+) circuit? Yes • Repair the (T69) Input Speed Sensor Supply (+) circuit for a short to voltage. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 9 9. CHECK THE (T52) INPUT SPEED SENSOR SIGNAL (-) CIRCUIT FOR A SHORT TO VOLTAGE 1. Disconnect the I-255 connector. 2. Disconnect the TCM C-1 and C-2 harness connectors. 3. Turn the ignition switch to the RUN position, engine off. 4. Measure for voltage between chassis ground and the (T52) Input Speed Sensor Signal (-) circuit at the I-255 (TCM Side) harness connector. Is there voltage present on (T52) Input Speed Sensor Signal (-) circuit? Yes • Repair the (T52) Input Speed Sensor Signal (-) circuit for a short to voltage. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 10 10. CHECK THE (T69) INPUT SPEED SENSOR SUPPLY (+) CIRCUIT FOR A SHORT TO ANOTHER CIRCUIT 1. Disconnect the TCM C-2 harness connector. 2. Disconnect the I-255 harness connector. 3. Check for continuity between circuit (T69) Input Speed Sensor Supply (+) and all other circuits in the I-255 (TCM Side) harness connector. Is there continuity between any other circuits and the (T69) Input Speed Sensor Supply (+) circuit? Yes • Repair the (T69) Input Speed Sensor Supply (+) circuit for a short to another circuit. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 11 11. CHECK THE (T52) INPUT SPEED SENSOR SIGNAL (-) CIRCUIT FOR A SHORT TO ANOTHER CIRCUIT 1. Disconnect the TCM C-2 harness connector. 2. Disconnect the I-255 harness connector. 3.Check for continuity between circuit (T52) Input Speed Sensor Signal (-) and all other circuits in the I-255 (TCM Side) harness connector. Is there continuity between any other circuits and the (T52) Input Speed Sensor Signal (-) circuit? Yes • Repair the (T52) Input Speed Sensor Signal (-) circuit for a short to another circuit. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Replace the Input Speed Sensor in accordance with the SERVICE INFORMATION. (Refer to 21 - Transmission and Transfer Case/Automatic - AS69RC/SENSOR, Speed/Removal) . • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). DTC returned after TRANSMISSION VERIFICATION TEST. • If the DTC returns after replacing the Input Speed Sensor, replace the Transmission Control Module (TCM) in accordance with the Service information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Transmission Control/Removal) . • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). DTC did not return after TRANSMISSION VERIFICATION TEST. • Test Complete. 12. CHECK WIRING AND I-255 CONNECTOR FOR INTERMITTENT CONNECTIONS NOTE: The conditions necessary to set the DTC are not present at this time. The code set because of an intermittent condition. Try to determine the cause in this step. Turn the ignition off. 1. Disconnect all TCM harness connectors. 2. Disconnect all related in-line harness connections. 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. • Terminals that have been pushed back into the connector cavity. • Perform a terminal drag test on each connector terminal to verify proper terminal tension. 5. Using the schematics as a guide, inspect the wiring and connectors specific to this circuit. 6. Wiggle the wires while checking for shorted and open circuits. Were any problems found? Yes • Repair as necessary. • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). No • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). • Test complete.
P07BF - 00 - Input - Turbine Shaft Speed Sensor 1 Circuit Low
P07BF - 00 - Input - Turbine Shaft Speed Sensor 1 Circuit Low For a complete TRANSMISSION wiring diagram, (refer to the Wiring Information) . Theory of Operation The purpose of the diagnostic is to check the turbine speed sensor circuit for electrical failures by continuously monitoring the sensor output circuit for voltage high, low, or open conditions. The turbine speed sensor is a Hall Effect sensor that has an output range that alternates between normal high and normal low voltages as the turbine tone wheel rotates. If the measured turbine speed sensor output circuit voltage is greater than or equal to a calibrated high threshold (circuit high) or is less than or equal to a calibrated low threshold (circuit low or open) for a calibrated amount of time, a DTC will set. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • TCM supply voltage is between 10 and 16 volts. • Engine speed (CAN message) is greater than 550 rpm. Set Conditions: • Input speed sensor output circuit voltage is less than or equal to 0.225 volts for less than 1 second. Possible Causes INPUT SPEED SENSOR SUPPLY (+) CIRCUIT OPEN INPUT SPEED SENSOR SUPPLY (+) CIRCUIT SHORTED TO GROUND INPUT SPEED SENSOR SIGNAL (-) CIRCUIT OPEN INPUT SPEED SENSOR SIGNAL (-) CIRCUIT SHORTED TO GROUND INPUT SPEED SENSOR TRANSMISSION CONTROL MODULE (TCM) Always perform the PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). Diagnostic Test 1. CHECK FOR AN ACTIVE DTC 1. With the scan tool, read TCM DTCs and record on the repair order. 2. Record the Event Data and Environmental Data. 3. With the scan tool, erase DTCs. 4. Using the recorded Event and Environmental Data, along with the When Monitored and Set Conditions above, operate the vehicle in the conditions that set the DTC. 5. With the scan tool, read TCM DTCs. Did the DTC return? Yes • Go To 2 No • Go To 12 2. CHECK THE INPUT SPEED SENSOR SUPPLY 1. Connect the scan tool to the vehicle. 2. Start the engine. NOTE: It may be necessary to allow the vehicle to allow the vehicle to roll while in a driven gear to see the voltage switching. If necessary to perform this test with the vehicle not stationary, enlist the aid of another person to operate the vehicle while monitoring the scan tool. 3. Place the vehicle in gear. 4. Monitor the Input Speed Sensor Supply voltage with the scan tool. Does the voltage switch from high (more than 1.2V) to Low (less than .8V) continuously? Yes • Go To 3 No • Replace Input Speed Sensor Supply and Transmission internal wiring in accordance with the Service Information. (Refer to 21 - Transmission and Transfer Case/Automatic - AS69RC/SENSOR, Speed/Removal) . • Perform TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). 3. CHECK WIRING AND CONNECTIONS AT THE I-255 CONNECTOR 1. Turn the ignition off. 2. Disconnect and check the I-255 connector. 3. Inspect the harness connectors and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. 4. Using the schematics as a guide, inspect the wiring and connectors specific to this circuit. 5. Wiggle the wires while checking for shorted or open circuits. Were any problems found? Yes • Repair as necessary. • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). No • Go To 4 4. CHECK THE (T69) INPUT SPEED SENSOR SUPPLY (+) CIRCUIT FOR AN OPEN 1. Disconnect the I-255 harness connector. 2. Disconnect the Transmission Harness Pass Through connector. 3. Measure the resistance of the (T69) Input Speed Sensor Supply (+) circuit between the Transmission harness connector and the I-255 (Transmission Side) harness connector. Is the resistance below 3.0 Ohms? Yes • Go To 5 No • Repair the (T69) Input Speed Sensor Supply (+) circuit for an open. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). 5. CHECK THE (T69) INPUT SPEED SENSOR SUPPLY (+) CIRCUIT FOR A SHORT TO GROUND 1. Disconnect the I-255 harness connector. 2. Disconnect the Transmission Harness Pass Through Connector. 3. Check for continuity between ground and the (T69) Input Speed Sensor Supply (+) circuit at the I-255 (Transmission Side) harness connector. Is there continuity between ground and the (T69) Input Speed Sensor Supply (+) circuit? Yes • Repair the (T69) Input Speed Sensor Supply (+) circuit for a short to ground. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 6 6. CHECK THE (T52) INPUT SPEED SENSOR SIGNAL (-) CIRCUIT FOR AN OPEN 1. Disconnect the I-255 harness connector. 2. Disconnect the transmission pass through harness connector. 3. Measure the resistance of the (T52) Input Speed Sensor Signal (-) circuit between the Transmission Assembly harness connector and the I-255 (Transmission Side) harness connector. Is the resistance below 3.0 Ohms? Yes • Go To 7 No • Repair the (T52) Input Speed Sensor Signal (-) circuit for an open. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). 7. CHECK THE (T52) INPUT SPEED SENSOR SIGNAL (-) CIRCUIT FOR A SHORT TO GROUND 1. Disconnect the I-255 harness connector. 2. Disconnect the transmission pass through harness connector. 3. Check for continuity between ground and the (T52) Input Speed Sensor Signal (-) circuit at the I-255 (Transmission Side) harness connector. Is there continuity between ground and the (T52) Input Speed Sensor Signal (-) circuit? Yes • Repair the (T52) Input Speed Sensor Signal (-) circuit for a short to ground. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 8 8. CHECK THE (T69) INPUT SPEED SENSOR SUPPLY (+) CIRCUIT FOR AN OPEN 1. Disconnect the TCM C-1 harness connector. 2. Disconnect the I-255 harness connector. 3. Measure the resistance of the (T69) Input Speed Sensor Supply (+) circuit between the TCM C-1 harness connector and the I-255 (TCM Side) harness connector. Is the resistance below 3.0 Ohms? Yes • Go To 9 No • Repair the (T69) Input Speed Sensor Supply (+) circuit for an open. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). 9. CHECK THE (T69) INPUT SPEED SENSOR SUPPLY (+) CIRCUIT FOR A SHORT TO GROUND 1. Disconnect the TCM C-1 harness connector. 2. Disconnect the I-255 harness connector. 3. Check for continuity between ground and the (T69) Input Speed Sensor Supply (+) circuit at the I-255 (TCM Side) harness connector. Is there continuity between ground and the (T69) Input Speed Sensor Supply (+) circuit? Yes • Repair the (T69) Input Speed Sensor Supply (+) circuit for a short to ground. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Go To 10 10. CHECK THE (T52) INPUT SPEED SENSOR SIGNAL (-) CIRCUIT FOR AN OPEN 1. Disconnect the TCM C-1 harness connector. 2. Disconnect the I-255 harness connector. 3. Measure the resistance of the (T52) Input Speed Sensor Signal (-) circuit between the TCM C-1 harness connector and the I-255 (TCM Side) harness connector. Is the resistance below 3.0 Ohms? Yes • Go To 11 No • Repair the (T52) Input Speed Sensor Signal (-) circuit for an open. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). 11. CHECK THE (T52) INPUT SPEED SENSOR SIGNAL (-) CIRCUIT FOR A SHORT TO GROUND 1. Disconnect the TCM C-1 harness connector. 2. Disconnect the I-255 harness connector. 3. Check for continuity between ground and the (T52) Input Speed Sensor Signal (-) circuit at the I-255 (TCM Side) harness connector. Is there continuity between ground and the (T52) Input Speed Sensor Signal (-) circuit? Yes • Repair the (T52) Input Speed Sensor Signal (-) circuit for a short to ground. • Perform the TRANSMISSION VERIFICATION TEST (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) - Standard Procedure). No • Replace the Input Speed Sensor in accordance with the Service Information. (Refer to 21 -Transmission and Transfer Case/Automatic - AS69RC/SENSOR, Speed/Removal) . • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). DTC Returned after TRANSMISSION VERIFICATION TEST. • If the DTC returns after replacing the Input Speed Sensor, replace the Transmission Control Module (TCM) in accordance with the Service information. (Refer to 08 - Electrical/8E - Electronic Control Modules/MODULE, Transmission Control/Removal) . • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). DTC did not return after TRANSMISSION VERIFICATION TEST. • Test complete. 12. CHECK WIRING AND I-255 CONNECTOR FOR INTERMITTENT CONNECTIONS NOTE: The conditions necessary to set the DTC are not present at this time. The code set because of an intermittent condition. Try to determine the cause in this step. Turn the ignition off. 1. Disconnect all TCM harness connectors. 2. Disconnect all related in-line harness connections (if equipped). 3. Disconnect the related component harness connectors. 4. Inspect harness connectors, component connectors, and all male and female terminals for the following conditions: Proper connector installation. Damaged connector locks. Corrosion. Other signs of water intrusion. Weather seal damage (if equipped). Bent terminals. Terminals that have been pushed back into the connector cavity. Perform a terminal drag test on each connector terminal to verify proper terminal tension. 5. Using the schematics as a guide, inspect the wiring and connectors specific to this circuit. 6. Wiggle the wires while checking for shorted and open circuits. Were any problems found? Yes • Repair as necessary. • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). No • Perform the TRANSMISSION VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Transmission Control (TCM) /Standard Procedure). • Test complete.
Tire Size
Consider it carefully on the rear axle gearing and the top gear of the transmission. As you found how it changed your truck getting the gearing correct. I've got that other member with Allison Transmission and the final gear is pretty tall and running way too low in top gear at 65 MPH.
P06D8 - Sensor Reference Voltage 6 Circuit High
P06D8 - Sensor Reference Voltage 6 Circuit High Theory of Operation This sensor supply circuit provides a 5-Volt supply to the Fuel Rail Pressure (FRP) Sensor. The Powertrain Control Module (PCM) illuminates the MIL lamp immediately after the diagnostic runs and fails. The ETC lamp will also flash. During this time the customer will be in a limp home mode. The PCM will turn off the MIL lamp after the diagnostic runs and passes in four consecutive drive cycles. When Monitored: While the engine is running. Set Condition: Voltage detected on the 5-Volt Supply circuit is above a calibrated value. Possible Causes 5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE POWERTRAIN CONTROL MODULE (PCM) Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). Diagnostic Test 1. ACTIVE DTC 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition off for 75 seconds. 5. Turn the ignition on. 6. With the scan tool, read DTCs. Did the DTC reset? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK THE (K350) 5-VOLT SUPPLY CIRCUIT FOR A SHORT TO VOLTAGE 1. Turn the ignition off. 2. Disconnect the FRP sensor harness connector. 3. Turn the ignition on. 4. Measure the voltage of the (K350) 5-Volt Supply circuit at FRP sensor harness connector. Is the voltage reading above 5.1 Volts? Yes • Repair the (K350) 5-Volt Supply circuit for a short to voltage. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 3 3. CHECK THE (K350) 5-VOLT SUPPLY CIRCUIT FOR A SHORT TO ANOTHER CIRCUIT 1. Turn the ignition off. 2. Disconnect the PCM C1 harness connector. NOTE: Check connectors - Clean/repair as necessary. 3. Measure the resistance between the (K350) 5-Volt Supply circuit and all other circuits in the PCM C1 connector. Is the resistance below 10k Ohms? Yes • Repair the short from the (K350) 5-Volt Supply circuit to the circuit that measured below 10k Ohms. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Replace the Powertrain Control Module in accordance with the service information. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
