  1. Sorry for the malfunction I've been working in the back end of the site so things have been a bit goofy... Again sorry for that...
  2. Should of done VCO nozzles. I had the same issue with stalling on my first set of SAC tips. Then changed to VCO and stalling problem was gone. The other thing I did was not opt for default pop pressure but went up to 320 bar. Way cleaner burn less smoke. Then now coupled with 30 inch tires with a final ratio at 3.69:1 and my economy tune now I'm hitting a high mark of 28 MPG. Typically get 350 to 400 miles on a half tank.
  3. Ummm... I'll patiently wait... Just like my mother professed that she would see the end time in her life time. Nope. Prayed for "Decades" and here we are still today in the same mess. I think its time of more action than prayers. Prayers are not going to stop the Gov't from doing what it doing to the people. Praying is not going to get Biden and the corrupt democrats out of office. Praying is not going to fix the inflation of the dollar and the troubled market. Praying isn't going to protect myself for corrupt cops or being killed by rioter. I'm not saying I don't believe but I believe you have to be more proactive to make changes than passive (praying) which doesn't fix anything.
  4. Only works good "IF"... Battery are in good condition and not discharged. Alternator is up to the task and not exceeding the 150 Amp breaker If the circuit breaker is tripping quite a bit look at the batteries. It not a circuit breaker problem nor is it a alternator problem. Even changing to a fuse its possible to keep blowing 150A fuses too. Again its the batteries that are not keeping up with the task. I've dealt with this in the past. Double cables on the negative did nothing. Changing from 150A circuit breaker to a 150A fuse did nothing. But now replacing the batteries that were weak problem gone...
  5. I personally say that we need to drain the Gov't swamps. We cant fix any of these problem when America is allowing all these DemonRats (Democrats) stay in control. We can pray our brains out and go to church every day but the evil will still be in control. Till the Gov't swamps are drained we are not going to get any better.
  6. That is because the Edge just stacks timing on top of the stock timing of the ECM. This is not optimal at all. Bigger injectors need a good amount of retard to get spooled up then you can advance timing on top more being bigger injectors are going to need more time to heat the fuel to a vapor, then go BANG on time. On the Quadzilla the ECM is in control till warm up mode is completed. Even my truck is a bit smokey on start up and getting rolling. Once out of the warm up phase then the Quadzilla will take over and use your tune. I've got mine set for 140*F for warm up.
  7. The dual battery cables will gain you nothing most likely. You can do a voltage drop to verify if the cable is needed but most of the time no. Even on my truck under load the voltage drop with stock cables on the negative side is 0.003 (3 mV drop). Then to verify if the dual is needed just hook up jump cables to each negative post and test again. In my case it was still 0.003 (3 mV drop) drop. So no change and nothing to be gained on dual cables.
  8. Sound like negative torque if the timing is advancing too fast on the upper end.
  9. The biggest problem is final ratio is too tall. 3.40:1 ratio is too tall and will cause tuning issues. Optimal is 3.55 to 3.73 and that will greatly reduce the EGT's fast. Tall ratio like that need a lot of retard to make it launch fast. That's why it a dog launch too much advance will cause the turbo to lag and not to spool. More your above 3.55 the more you need to retard to get launched. So your tune starting at 17* is insane... 13.0, 17.5, 22.0, 26.5 this would be good for your final ratio. Just for fun and info. I had a tune based on 13.0, 18.5, 24.0, and 29.5 which built upwards of 51 PSI of boost and blew my head gasket due to the choke point of my turbo 12cm2. But that combo worked really good I could light up the tires in just about any gear I wanted. Build power super fast but the MPG's was a bit lower because of the negative torque. After replacing 2 Cummins OE gaskets (which are not made by Cummins but a company called BLK) and bring my timing down to the one above now I'm got the efficiency a slight loss to top end power but with high MPG's I'm not complaining.
  10. Junk. There again the sensor is based on electronic means to translate simple rheostat and a 2 switches. So far the Timbo APPS lasted over 300k miles and like 8 years. Still cheaper than the Wells Magnetic which can have failures electronically just like the factory OE APPS the failures between the rheostat and the electronics.
  11. Most likely could measure the cables and get close enough. Yeah your going to want to pull the drums.
  12. DOM of 2/00 is a 2000 truck for sure not an 2001. Now the was short bed and long bed so the cables has to be removed and measured to get the right ones. Don't feel bad I've got my 2006 truck I need to do the same thing. Driver side is all bound up just like yours.
  13. No need for bigger tubes or lines like said above when your over 600 to 700 HP. Keep in mind bigger lines and tubes are going to offset timing more retarded being it will take more pump time to Reach pop pressure.
  14. I agree with above comments. Bump the starter with the key this will start the prime cycle of the lift pump. Check you work for fuel leaks not to mention is the lift pump working?
  15. I would rather opt for... 14.0, 18.5, 23.0, 27.5 for max timing on any hotrod or modified pump with an auto. 13.0, 17.5, 22.0, 26.5 for max timing with again a modified pump on a manual 5 or 6 speed.
  16. Galled or seized timing piston will not throw any other code but a P0216 code. Which yours did. I've seen pumps so seized up your had to heat the case of the pump with a propane torch to get the piston freed or to even slide out.
  17. Also really common for the timing piston to gall up and seize in place. If the is no p0251, p0252, p0253 or p0254 codes the solenoid wires are fine.
  18. When the P0216 code is set the Quadzilla only reports commanded timing not actual. Like my last pump was stuck full advanced. Very hard knock only got 25 to 30 MPH.
  19. Those are in sad shape. I'll let you know that brake fluid should be changed every 30k miles and that doesn't happen. After a period of time the brake fluid will absorb moisture and start to rout out the bores in the calipers and rot the seals.
  20. Just some common bar to PSI conversions and the pop pressure spec according to Dodge Factory Service Manual. 1 bar = 14.5038 PSI 293 bar (minimum allowed) = 4,250 PSI 300 bar = 4,351 PSI 305 bar = 4,423 PSI 310 bar (stock OE injectors) = 4,500 PSI 320 bar = 4,641 PSI 327 bar (maximum allowed) = 4,750 PSI Being I opted for custom pop pressure being it takes just a bit more time for the VP44 to reach the pop pressure this makes my timing slightly off and retarded. I'm fine with that being I can fully adjust my timing to what I need to get the most from the injectors. As most found out 28 MPG is not impossible with 150 HP injectors. This custom 320 bar pop pressure I make up on the Quadzilla tuner. Another thing to remember its not uncommon for a injector to settle some after being built and dropping about 5 to 10 bar off its set pressure after about 20k miles. So the extra pop pressure is also buying me extended life on the injectors. The way to tell typically is watch the engine load value and the idle RPM. If the injectors are working correctly there should be a engine load between 2% to about 15% and idle at 800 +/- 10 or so. When injectors are wore out thne the idle will be >800 RPM and engine load typically will be ZERO%. This just shows the pop pressure fell out and the ECM can't defuel enough to hold an 800 RPM so it starts to high higher.
  21. Sold them all... I will say that Timbos APPS lasted much longer than the factory OE APPS sensor which bare made about 180k on The Beast.
  22. Even though I've got the p0122 present it still drove ok. Once in awhile it would drop out for just a second or so and pick back up. Mostly in town at 25 MPH because of light throttle needed.
  23. I'm going beyond the normal. Typically most injector builders will pop them slightly lower than stock. Stock pop pressure is 310 bar or 4,500 PSI. Now for performance most will drop to 300 or 305 bar for better flow. I went the other direction and popped them high at 320 bar v(4,641 PSI). This made for cleaner spray pattern and better fuel economy. This is why I like @dieselautopowerfor my injectors is because I can specify a custom build and they will build to your spec. So there default pop pressure will be fine for most applications but in my case I went out on a limb to gain my high mark... 28.04 MPG on a 2002 Dodge Cummins. Was it worth it? Yup! sure was...
