*Oil Consumption 5.9 Cummins with 87K-Valvoline Premium Blue Restore Oil*
I wonder if the the valve guides were replaced?
Greasing front wheel bearing hub.....
Remember if you get too much metallics in the grease between the tone wheel teeth the the ABS will freak out and set the ABS and BRAKE lights. Not something I willing to suggest. The tone wheel should be kept clean and not filled with grease. Being if the grease has a bunch of metallics then the ABS doesn't count the frequency even and may or will cause ABS issues later on.
Odyssey of the bucking and surging
My last Quadzilla failure was similar. I found that my ring terminal for ground was lose and created the same problem you had. I've seen one other vehicle with a bad set of red and red/white wires so the Quadzilla wasn't getting good power. Disconnecting the CANbus just stops the Quad from talking to the ECM and VP44. If it straightens out then look into the wiring more so and double check all the connections. DO NOT hook directly to the battery for either the RED positive or the BLACK ground wires. In the PDC box there is a red wire stud in there to get power. Then hook the black to a the body or engine block it doesn't need to be on the battery at all.
Disconnect the Quad CANBus connector and see if it goes away if so the Quadzilla is having either power or communication problems.
There is no way to see the default tune that is shipped. You'll need to create a tune to make it what you need. Not hard nor long to do. You want roughly, 13° @ 1.5k RPM, 17° @ 2.0k RPM, 21° @ 2.5k RPM, 25° @ 3.0k RPM, 26° MAX for starting. I know this might be too retarded but safer to be retarded than over advanced... Here is what I'm running for my set up. Be aware with the cruise timing high like I run it does buck a bit on low RPM's just drop that to between 2 to 4 degrees on the cruise timing.
Most likely need to configure your timing for your engine. What is your current timing on the Quadzilla. Pay attention to the RPM and the engine load when your load is low and cruise timing is enabled you could possibly be over advancing the timing. It would help if you uploaded your current tune settings or at least post the Max Timing and the other timing parameters so we can see. Yes bucking is cause by too much timing advance.
Take notice to the amount of carbon. Like this truck was short tripped a lot and never got up to operational temperature much. Because if you get up over 1,200 EGTs that carbon and oil wouldn't be there.
Valve guides and valve seal would be my next step. I had done mine back at 350k miles being the vlave guides wore enough to allow the valves to wiggle and then ruin the valve seal that are harden and no longer flexible. Be aware the head will require removal and new head gasket require. Don't just do new seal being the seal will most likely be ruined being the guides might be worn. No way to get around this.
Grid heater bypass question.
Being my random travels it makes no sense to plug in. Some days I don't leave home other days I might leave at 8am, 9am, 10am etc. Not to mention im on limited power here being daylight hours are short. If im heading south im warmed up in 5 miles with heat. Go north it will just about take 10 miles. If I want super fast warm up set 3 CYL mode flip on the exhaust brake. EGTs sore to 900 to 1000. I can go from -20F to fully warmed in under 10 minutes.
COVID blues
I'm glad I got 9mm back after the last shortage. No warning shot given due to the price of ammo.
Hello From Tri-Cities, WA
Just think the stock engine and injectors with turn 235 HP. Now drop in a Quadzilla Adrenaline tuner and that is capable of 180 HP. So for safety sake that would make 355 HP to 415 HP just with tuner. There is a bunch of supporting mods to do to make this happen... AirDog 150 or FASS 150 with 1/2" fuel lines is a requirement. (Currently running a AirDog 150) Automatic transmission will need to be upgraded to hold the power. Manual transmission you need to look at better clutch. (Currently running a Valair Dual Disc) If your running over sized tire, then to get your final ratio correct (3.55 to 3.73 to the ground) Suggest looking at ARP 425 studs for above 400 HP as a safety measure. Possibly look at slightly larger turbo. You can do it on a HX35W but the EGT's might get a wee bit hot. (Currently running HX35/540 Hybrid) 4 inch exhaust. Don't bother with 5 inch your not going above 600 HP. I can go in to detail on any subject you wish.
Just to make a serious jump I would suggest just gettng a Quadzilla Adrenaline which is a nice 180 HP jump in power. Fully adjustable tuner that adjust not only thre fuel but also can adjust timing for the VP44 trucks. I'm running 150 HP injectors (7x0.010) popped at 320 bar, with the Quadzilla and my Economy tune I'm right at about 500 HP and 19 to 21 MPG. I got the best of both worlds good economy and more than enough power to light the tires up on dry asphalt. Just to give you a feel... As for all the mod check my sig for my modification list and there is 4 pages worth.
Yes and no... Yes if you disconnect the little leads on the solenoids. That will trip both the P0380 and P0382. No. if you disconnect the battery power at the drivers side battery and pull the main power leads. This will not set any codes and allows for normal operation but there is no power to the solenoids. ECM is still hooked up and triggering the solenoids but just no power to the grid heater. This is what the solenoid is suppose to do as well. You can switch on and off the power to the main leads. As another member posted up that the solenoid burned. With my method there is no contacts to burn or have to toggle the solenoid on and off. For me April is the spring start and typically the weather is above +32°F outside there is no need for grid heater all spring, summer, fall. Then in October the weather get cold and I hook them back up and run them again till April. This saves the contacts in the solenoids on the fender not having to preheat and post heat every start. PRE-HEAT is most done with the IAT. The post heat is done by BATTERY TEMP sensor. So like I could be fully warmed up, MPG fooler ON (143°F IAT) and still end up with post heat because the battery temp could be below 60°F which will cause post heat regardless of ECT temperature and IAT temperature.
7.3L Powerstroke Pedal Assembly Rebuilder
I was handed a rather good challenge to fix. I needed to have a pedal assembly rebuilt being salvaged pedals assemblies tend to all have the same fault wore out on the clutch bellcrank pin and bushings. I did a bit of Google search and turned up a guy named "Altered Ego" that does awesome work. When he got the assembly I sent in he called me and told me it was the worst one yet to see and totally wore out. Now after 2 weeks of freight time and waiting for pedal pads I got it back and it looks excellent. Even with grease zerks in the pivots. All upgraded with brass bushings, removed all the plastic. Total Cost $460 for the rebuild and upgrade.
VP44 Question
OEM VP44 should have a VOID sticker wrapped around the VP44 connector preventing removal of the plug without tearing the sticker off.
Finally done it
I'd love to give you +5 likes for that... That is one of my biggest factors is to make sure to allot enough time to do quality work and cover all bases. It when you pressed for a time schedule then you start to screw up rushing a job. One of the few jobs I got hired to do was working at the local Chevron Station for a summer. It was really tough to hold to a narrow slot of time to do big job. This is why I went into doing my own business and no longer held to a tight time schedules.
Still to this day I do the control of the grid heater manually. April I will disconnect the main power feed to the grid heaters. Then in October I will hook up the the power lead again. My truck will start as low as +20°F above without grid heaters. I stumbles a little but starts fairly easy. At +32°F starts like a summer morning. I don't even consider block heater till below 0°F.
Thuren alignment specs?
They use tons of salt out here in Idaho now. That is one of the biggest problems I face is rusted fasteners for suspension and other thing external to the cab. For all that stuff like the camber adjustment you could pull the bolt out and mop on the anti-seize and reassemble.
COVID blues
Now the bad news it snowing... Ugh! Now I get to work in the snow and cold today. For the moment I'm happy as heck to sit right here at my desk where its warm and dry. Last thing I wanna do is get dressed and haul out to the yard to install a pedal assembly in a Ford Powerstroke.
Finally done it
That's what it feel like for me now. Seem like I run my tail off all day and still get stuck with one issue or another preventing me from completing a job (wrench work). Then like this morning I'm up a bit early and working the website making sure the server is running top notch. Still finding weird issues and configuration issues. This is why I'm looking at the hotshot angle it would allow me to do jobs possibly local to me and in the spring of the year be a good time to break free after a long winter of being cooped up.
Hydroboost problems
I get it on the road repairs are a pain and yeah I get that the idea of rebuilding a hydro booster in a hotel parking lots isn't happening either. 423k miles later it might be on my list of things to do in the near future too. I've been keeping my fluids changed and flushed out often so maybe I can get it to hold up a bit longer.
Finally done it
I'm about ready to follow the same idea. My plan is to find a standard cab 2nd gen Cummins. Then remove the bed and install a utility box and load it up with tools, welder, etc. Now travel around my own area doing wrench work. I figured if I built the truck right I should be able to haul my RV as well. That way say I could drive out to @JAG1place to do a set of ball joints for him. Then have another job in Oregon and job form job to job till it leads me home again. Then other idea would be to fix up my truck but hook up with U Ship and start doing hot shot work with what I got. I've seen a job about hauling a small dog to Colorado. I'm like no problem. Just would plan better so when I left that job I would hook up another job to bring me back home again. With everything I done to increase the truck longevity I'm in good position to start do that kind of work too.
COVID blues
I bought 4 sheets of 3/4" OSB board and it cost a bit over $39 a sheet. OUCH! On that note if I order anything from Oregon it got to make a trip all the way past me in Idaho to Utah to come back to Boise. Adds about 2 days to shipping. Thankfully enough... I already loaded up with shooting supplies while back. Not one of my common activities so my stash will last awhile. Good News. The pedal assembly for the Ford Powerstroke came in last night at like 6pm. I know what I'm doing today.
COVID blues
Man I'm getting rather wore out on everything being late and held up because of COVID... I know I posted this on a few other threads. Like @Wet Vette ask me to fix the old dish washer in the house. I did a few simple repairs of the float switch and the water line. Got it to run once again last for about 2 weeks and then the motor locked up. I tore apart the pump head and found a scrubby pads wound up in the pump head. Clean it up and it last another wash or two and then the bearing froze up in the motor. Ok. We both agree to replace the dishwaher. Head to Home Depot and looking at dishwashers and there is huge sales on some quality units. We got our eyes set on a LG that is all stainless steel body and door. Caught the black friday sales and now reduced to $498. Asked if there any units in stock. NOPE. I pay the bill and found out it will not come in till FEBRUARY!!! What?! OK... COVID... OK. Another common repair is replacing a fan belt on a 2003 Dodge Dakota. Called the local NAPA store. Typically if they don't have it the store they can get it from Spokane by the next day. NOPE. They had to get it from another store in another state outside the normal travels. So its takes 1.5 weeks to get a fan belt. OK. Now I've got my steering box pulled out and shipping it back to Blue Top for rebuilding. Got it down to the US Post Office for shipping in a flat rate box which is normally 2 or 3 days. NOPE day 4 and notifying it will be late and still in transit. Man just to get a steering box from here to Blue top is now taking a week just about. UGH. Still got to wait on the return trip after he gets the part and ships me a new one. Now my truck is trapped in my shop till I get the new unit. I can move my truck till I do. OK. Another one. I got a job on a 1995 Ford Powerstroke that need a pedal assembly rebuilt. I found a guy in Arizona that rebuilds pedal assemblies and he got the old one and notified me that was the worst one he's ever rebuilt. Now he called me last week telling me he was shipping it back I'm still waiting on the rebuilt unit to get back. This is making job super long. As your seeing I'm super done with all the COVID issues in the world and its making my job slow and just can't get anything done being parts are just tough to get and get them shipped in a timely fashion.
Alternator question (and may a stupid one)
Alternator could be hook to a shorted battery and still won't blow during normal run. Fuse is 140 Amps and the alternator is 136 Amp Wide Open Throttle. Hence why the grid heater come on demand 195 amp (both elements) and alternator does not blow the fuse or trip the breaker. Now say your front end collision and the alternator snapped off the mount slammed into the block that would be a dead short on the charge lead now the battery will out power the fuse and blow, not the alternator. Being the batteries total are 1500 amps (or more) with both batteries (stock CCA). See the battery cause the fuse to blow not the alternator. Being the alternator on high idle still can reach 136 Amp with the grid heaters but doesn't blow the fuse or breaker. Not suppose too... Technically the grid heater are a dead short of sorts being that it draws 195 amps (both elements) at 14.0 volts that is 0.071 ohms. Yeah that's a in a nutshell is a controlled short that creates roughly 400*F to 500*F temps in the manifold.
