mopartechnician
Everything posted by mopartechnician
  1. The low voltage thing can happen to anything that updates the computer. We would have to hook a battery charger up any time we did a flash for chrysler. And, im pretty sure in the smarty instructions it says the same thing. I have never seen any problems with a smarty and I know they have backup files if you ever did have problems with a download. We ran one with an adrenaline on our sled puller and it was amazing. I only suggest people run smartys on third gens and hopefully they start working on the 2nd gen custom tuning.
  2. 4.8 hours on a 24 valve. According to alldata
  3. Holy ****. Its only a 6 hour job. Parts are only 30. Im doing one on a 12 valveand only charging 350
  4. Depends on the clutch. Like i said, call those guys and they will tell you exactly what you need and what to do with your dreams. I wish i could find a cheap 12v. Got one in my garage right now to fix tappet cover gasket and do some timing
  5. Some people calve early in the year some calve later. You dont make as much money if you calve late since your calves are lighter. My dad and the guy he helped would calve late and we wouldnt brand until mid june
  6. 120 micron is not restrictive. I just onstalled a fass and it came with an inline filter
  7. Oh ya some of the newer raptors didnt have them. They were plugging up with junk. Thats why they started telling you to put an inline pre-filter
  8. 03-04 have a smaller piston bowl right? Thats why you can spot bad injectors better in a 03-04 than the newer years because it sprays on top of the piston and not in the bowl. Am I close?
  9. Browns is out of california. Thats where I get all my parts for the pickups i work on. Thei website is brownsdiesel.com. They really dont have much on the site last time i checked but if you call and talk to them, they are extremly smart on what works and what doesnt.
  10. It will not run at all or will run and then die. Once there is fuel in the motor, its all over. I had one that was really loud, called pureflow and they sent me a new one no questions asked
  11. Western nebraska
  12. 28 with wind chill of 9. Blowing snow and can only see about 50 yards. Oh and I say 50mph gusts
  13. Get rid of fuel plate and adjust star wheel. Advance timing. Those are easy and free mods. Call Reb or Erick at browns diesel and tell them I sent ya, they make 12 valves go fast Here is their ace of spades sand drag pickup. This is built with extra parts laying around the shop http://tbilisitube.com/en/video/GcB66fKEa1I/Browns-Diesel-1110rwhp-and-FIRE
  14. Thats because yours is a 02. They started using the orange/pink stuff on the 3rd gens
  15. 2 micron filtration is key
  16. So your saying the coolant that comes from the factory isnt good for it?
  17. Dont use green. It cant be used on the types of metals. That is one of the reasons they switched
  18. Yes the coolant is a orange color, the p/s pump turns all the time so it can make noise anytime the engine is running. You need to add some Atf+4 to bring the level up. Its probably not going to stop the noise. Also if you have an auto, make sure your dipstick tube isnt rubbing against the heater core hose or the cab. You will understand when looking at it. Now on a water pump leak it will usually leak down the passengers side, but it could be blown around by the fan. You need to look at the underside of the upper radiator hose that goes into the radiator. I have seen them leak there and the only way I found it was by running my fingers under the hose and finding water. Also look at the drivers side radiator end cap for leaking. A good pressure test usually will find a leak
  19. Bosch motor sports
  20. I have never seen one and I have pulled many tires on many different makes and models
  21. In the us they cant void your warranty just because you delete and i dont believe your buddy. I have never heard a new ford getting over 15 mpg around here
