thracing
Everything posted by thracing
  1. time too pull the head. you got internal problem,s dropped valve ,hole in a piston. i would not run in any until you have a look no need too make it any worse that its going too be
  2. cv joint in the front shaft sounds like its shot
  3. have you givin any thought to a power pucki have some customers here that run them and like them ,they to are pulling large trailers .heavy loads with no problems.they don,t break the wallet eather.01-02, 50hp/150tq10 minite install.
  4. a gauge is the proper way to go
  5. no offence mich but with roads plowed that nice i would run in 2wd too lol. over here anyone in the country ,we have too break are own trails,out to a main road 80% of the time so 4wd is not only a must but a way of life, the only 2wd you see here are in town or the bigger citys
  6. your 2wd would be no good here. as soon as the snow hits here you would be parking it
  7. good point, but most guys want the hight not the stiffer ride
  8. go too your nearist spring shop and get a couple of higher blocks for the rear
  9. fenwick ont here 10 minites outside of niagara falls
  10. 10 minites outside of niagara falls here
  11. most will see a drop up too a 100* in egt,s after the swap I RUN A HOUGE EQUAL LENGTH stainless hedder on my truck egts dropped 200*
  12. afe mani.s are 480 plus ride
  13. i have sold 30 afe exh maniflods this year .they seem to work real good and are priced right.the guy,s like them up here
  14. `sounds like you may have air locked it you say you seen lots of bubbles when you cracked some line and it quit after you did a filter change i would just reprime the pump she should catch and fire up again
  15. if you are sucking air its going too be somewhere between the tank and the pump,as for the filters it will make no diff if they are full or dry the pump will prime its selfdos the pump sound like its running hard or free?free its air, hard its a pluged filter if you are finding bugs and dirt in your fuel system chances are she ran low and pluged its self solid
  16. its that time of the year again dyno day oct 22 bbq, prizes
  17. you mean ring and pinioncheck your drive shaft u-joints first bad u-joints will clunk going into gear if it is the rear diff pull the cover and have a look if the crown or pinion still have all there teeth if so just reset your lash and off you go
  18. it all depends on how much tone/noise you want mbrp cool duels is a very good kit , gave me a solid 2 mpgdimound eye has some good kits too add a s+b cold air filter and off you go you would not be disappointed
  19. My Mother taught me:Religion ........ "You better pray that comes out of the carpet"Logic ............."Because I said so, that's why"Irony............."Keep crying and I'll give you something to cry about"Wisdom......... "When you get to my age you'll understand"Justice ..........."One day you'll have kids, I hope they turn out just like you!!"
  20. you got a bad stat , i see it here all the time, customer,s op for the cheaper stat,s and run into trouble
  21. new toy i picked up last week in indy,some mods done are custom south bend clutch,r850 twin setup, industrial injection dual cp3 kit , race 8 90 lpm-edm/extrude balanbed 500hp injectors,ssr smarty, s+b cold air intake +elbow,hamilton custom ground billit cam + 150# 5000 rpm springs, mahle coated + chamfered .040 pistons,block studded, mains,head, fire ringed, mbrp cool duals , 8"pro comp lift, alcoa 24.5x8.25 billit buds with michlins,detroit lockers front+back with 5.28,s, more auto meter gaging then anyone needs lol going too see what its got on the dyno in a couple of weeks
  22. A College Professor stood on his chair & said If GOD really exists then knock me off this chair. Nothing happened, the class was quiet he said See! now I'll give it a couple more minutes. A Marine Vet stood up, punched him in the face knocking him out of the chair then sat back down. As the Professor came to he looked at his student & said WHY DID YOU DO THAT? He said, GOD was busy protecting my buddies still fighting for your right to say & do stupid stuff like this so HE SENT ME........
  23. no bikes in this shop lolgive me a call 905-892-9524 as for bob
  24. you will be ok 01-02 are the same box from edge
  25. fenwick on canada here 25 miles outside of niagara falls
