tbo1450
Everything posted by tbo1450
  1. I just changed out one of my bearings. I think it's still in my junk pile. @Mopar1973Man. The bearing has major play but the tone ring is ok. U can see the ring through the abs hole.
  2. I used the old man buzzard trick. Haha. Used and extension and over size socket up against the hub bolt and knuckle. Started the truck turned the wheel. Pop right out. Once the hub and rotor assembly is out. I beat the wheel studs out with a brass hammer. 3 or 4 blows. Studs came right out. The hub and rotor come right apart.
  3. I got a 99 2500 with the old school setup. Hub and rotor held together by the wheel studs. Just replace the pads and rotors and speed sensors today.
  4. I think ur right. The sec ball and spring I got lasted a few months before things started to get weird again. I also thought the ball was the problem. It's a steady 17 18 psi now. Been steady for months. Good to know that about the air dog spring. I'll def get one if it acts up again. Strange fass doesn't offer one.
  5. Mine was erratic. All over the place. My sec ball and spring too. Even when I hit the brakes the fuel pressure would spike. Like the spring was weak. ??? Fass was being *** about sending me another ball and spring. So I shimed it.
  6. Mike told me too shim the spring. I had 10psi to 7 psi bouncing all over with my fass 95 ti. I put one brake line washer inline with the spring. I have steady 17psi. I don't rec to stretch the spring. It got worst when I stretch mine.
  7. My socket drawer. I got a problem. ?
  8. Just pick this up a few months ago. Haha ????
  9. I'll look when I get back to work. I forget exactly what year truck I was looking at. I just was searching for tsb's for gen 2 Cummins. What year is ur truck? I can get more specific with the updates. If u know ur software part numbers I can run them and see if there is an update for ur computers, and exactly what the update does.
  10. found this... 1) flash for pcm SYMPTOM/CONDITION: A change has been made to the PCM software to improve the durability of the transmission internal friction components when certain Drive-Reverse-Drive shift maneuvers are made which are associated with, but not limited to, snow plowing activities. 2) flash for ecu.. There may be a condition of low power or slow acceleration when towing or when hauling a heavy load. This software change, to the Cummins CM551 diesel engine controller, will increase engine torque 3)flash for pcm... SYMPTOM/CONDITION: flash for pcm Some customers may complain that their vehicle speed control system may be too busy or drift more than 2 mph below or above the initial vehicle set speed. Vehicle load and road / terrain conditions may impact this issue. The new PCM software improves the speed control system sensitivity so that the vehicle speed remains closer to its set speed with fewer engine rpm oscillations.
  11. Reflash is erasing the software in a computer module and reinstalling the most up-to-date software. Any computer in our trucks can be updated, if there is one. I've flashed both the pcm and Cummins ecu in my truck. Looking at the service bulletin I don't recall anything to do with fuel.
  12. Not a big deal. I've delt with diesel in gas motors alot at my dealership. Drain it out. Take it for a beat run. Good too go. They will try to tell u it needs everything tho. Haha
  13. This problem happens to me too. Started 4 months after i install rv275 injectors. Only happen like 4 times but its always cold and im always on the gas going up a hill. 99 ctd,nv4500, banks power pack tlc, rv 275, bhaf , new south bend clutch , mopar man high idle switch, fuel pressure gauge, etg gauge, boost gauge, oil temp gauge. Fass fuel ti 95.
  14. Had one not going into lock up. Found the brake switch was bad. Preventing it from going into lock up. The ecu saw that the brake was on. Easy fix.
  15. I installed a south bend single with a new flywheel in May. Shuttered a little bit for a couple hundred miles. Once it broke in no problems. I'm happy with it.
  16. Part number for the actual tranny?
  17. Not really sure where to post this.. I work at a dodge dealer and can get any factory part that is still available for 50% off the list price.. P.m. me your vin number and the part you want, Ill see what i can do.. Any part u need ie turbos, radiators, heater cores, ac evaps, anything.. Cant do it for everyone, but first few guys no problem. Love this website, everyone helping each other out with our trucks. Id Like to help out a few guys get some parts cheap.. Timmy
  18. I just got my high idle kit in the mail, Very well made. I wanna install it in the overhead console, but i def dont want to cut it up to extend the wiring. Mike do u have a p/n or website for the connector at the switch. i would like to make a extended harness for it. Thanks
  19. Probably the regulator/motor. U can check for power at the motor while actuating the switch. Then u know for sure the motor is at fault.
  20. if the pcm is not updated to the lastest software where the high idle is. will the smarty be able to still activate it? I keep saying PCM its located in the cummins ECU.
  21. I work at a dodge dealer. They definitely can enable high idle for u. its easy to do. They don't need the vin. Hooking up the old drb scan tool to the truck. Getting the software p/n on the pcm. Run the tech tools program to see if it's up to date. If it is, just gotta enable it with the drb. 3 cyl high idle enable is under engine then misc menus on the drb scan tool. Tell them that. They will know what ur talking about.
  22. Jb weld will def. seal it. I had the same style fuel filter . Mine was leaking fuel from one of the test ports. I jb welded it, ran her for a month until I got a fass.
  23. Got a manual trans with the Genos cup holder. Fits well. Also installed a dual USB port. o
